360 Magnum Pictures
Turns out that the 727 is non lockup, so that is good. I have a reverse manual VB I need to take apart and see what is wrong with it.
I bought it used and had first and reverse in my wife's car, but no 2nd or third.
I can't believe how much they have gone up in price. I have always bought used and never paid over 75 for one.
I could use 2 more. Maybe 3 if I can't figure this one out.
Don't forget a bolt in rear sprag if you are going rmvb.
Well, we waited out the cold weather, and are now slowly making progress.
My sons Brian, Matt, Tim and I just got the Magnum and 727 sitting on their mounts.
Now the fun begins! We will try to get a little done everyday, but some days it probably won't amount to much.
I need this done so I can start on my Old Yeller sweptline!!!
I went out and checked the headers Matt got from Jadaharabi at Indy and they will go right in!
I cannot believe how easy. I shoved the drivers side under and hooked it with a piece of #9 wire and pulled it right up!
Pass side goes in easy from the top.
I am now officially a fan of trucks!!
Now, if I can find some bolts I will have them on....
Took longer to find bolts than to install the headers.
We got a few other things done. We will have to switch to the other style alternator brackets, the a/c style will not work with the R/T heads unless I cut/ weld it. I have a few of the regular brackets, but I will have to dig for them.
We will also have to make the throttle bracket work with the Magnums vertical bolts, but that should be easy.
