hemichuck
I have a 408 short block that I've had built for a while with a forged 4 inch crank, eagle rods, and Icon 4.03 bore flat tops with valve notches with zero deck. I have a set of Edelbrock aluminum heads and a Holley strip dominator intake. I know that the stroker motors can run a lot more cam than a standard stroke small block and I was wondering if anyone had some guidelines to go buy when I am deciding on the cam lift/duration/etc. This engine is going in a 1970 Dart Swinger with 4 speed trans. The car is an original air conditioning and power steering, power disc brake car and I plan to retain all of these options. I will be running 3.23 gears and plan on driving the car a lot. I would like to know what the current thought is on choosing a cam for this application.
