This is an old favorite of mine. Still good info.
The 4-pin should work with a dual ballast as the missing pin is the one that goes to the ballast.
The difference is the 5-pin gets a reduced power from the ballast along with 12v on another pin. The 4-pin gets the reduced voltage internally from the 12v feed.
Alan
LOL, right?Key word = "should"![]()
Since you didn't bother to read my question and everyone else seems to have figured it out, I'll help you. I'll go slow, I know weed is free in Cali. The question is about MOPAR electronic ignition.Depends on the year and perhaps engine, which the OP didn't bother to mention. For anyone that needs to rewire anyway, I suggest dropping the Mopar ECU and ballast and changing to a GM 8-pin HEI module & coil (85-95 V-8 trucks). Simpler wiring, hotter spark, and more reliable. TrailBeast here sells as a kit for those who fear junkyards. While in there, smart to add a relay off BATT+ so you don't rely on the bulkhead connector resistance, and insure you ground the module well - not a rusty sheet-metal screw, applies to Mopar ECU also.
Thanks, Del. I really think it's in the connector. Have tried 2 distributors.Well the 4 pin should work. If it doesn't either the ECU is bad, you are not grounding it, maybe a bad harness pin connector. The crossed wires on the distributor don't matter so far as "getting a spark." If the pickup wires are crossed, this moves the spark event in relation to the rotor, IE "rotor phasing."
It also might be that due to the Chineseoizationized aftermarket, the "new" 4 pin need a bit more trigger power. And it might be that the distributor/ connector/ magnet/ gap is such that it is right on the border line.
If you can, scare up a different distributor
If you have a tach, try disconnecting that. Make sure there is NOT a radio supression cap connected to coil NEG. It goes to the pos. terminal.
Other than that, "I got nuttin"
No ****? Amazing. Thanks!View attachment 1715339946 Mine went out a few years ago. Just happened to be in front of an O’Rielly’s when it did. They had 2 different ones in stock, and neither worked. They ordered this Borg Warner in for me, and no problems since. I kept the box in case I ever had another problem. It is a 5 pin. This is on my '73 Dart Sport.
Only thing working right now is a five pin! LolHope it works for you.
Sorry Red, was on vacation and missed this. Just got the NOS 5 pin I'm going to try next. I'm right in the middle of a new harness install so it might be a couple days before I do.Just following up. Were you able to find the module and get going?
Thanks Kim. Even though I'm a Navy trained computer/electronics guy (DS), I still think there's voo-doo involved with this ****, haha.I have been there/ done that with the Mopar 4 pin ecu’s not working on the 5 pin harness. Ive also had lots of 4 pins work with a 5 pin harness and dual ballast. I’ve also wired in a single ballast to a five pin box and the box overheated and killed the motor. Let it cool off and it would run till it overheated again. Then again some worked. Kim
If it doesn't work after this, that could compound things!
Have you tried grounding directly to battery?? I had one that had a clean bolted ground to inner fender. Wouldn't run. Lifted the ecu up and it started running, while sparking
and thus grounding to firewall. The fender wasn't grounded.
At this point I'd be starting over trying to eliminate the variables.
I'd start with a raw (new) ignition harness.
P3690152AB MOPAR ELECTRONIC IGNITION HARNESS WITH TERMINALS ENDS AND HEAT SHRINK | eBay
Connect Light Blue directly to 12v
Connect Black/Yellow directly to the Coil (-)
Connect Green to ballast (if testing 5 pin modules)
Grind paint from module mounting screw hole, use bolt and tie directly to ground with wire.
Everything else should stay as it was (coil + to ballast)
Test
Alan
LOL. Agreed. It's a good way to learn!Man, I'd be troubleshooting just on the principle of the thing at this point.
Or kill it with fire.
Good on you
Well I did learn more about Mopar electronic ignition. Mostly what I learned is the modern 4 pin ecu's like a good working, charging/electrical system pumping out 12.5 to 13.5 vdc. The old 5 piners maybe can survive with much less voltage (I was using just a well charged battery during testing). But the Chinese specials ain't happening. The re-wire of the car interrupted my fun with ecu's game. As soon as I wired in the alternator and voltage regulator, starter relay etc. all the issues disappeared. Tried a couple 4 pinners and car likes them now. Lesson learned.
Props to @67Dart273. As usual I think he was on the right track:
"It also might be that due to the Chineseoizationized aftermarket, the "new" 4 pin need a bit more trigger power."
