I'm looking to build a 400+ HP 273 all the info I've read so far says it can't be done or cost to much or not streetable.
But a lot of these naysayers like to Quote "There is not replacement for displacement" which is true for torque. Torque is the function of how much fuel and oxygen you can get in every intake stroke and how much it's compressed. Horsepower is how much fuel and oxygen you can pass through the engine in any given amount of time (RPM).
The problem with 273 is the bore size of 3.625" it will limit the displacement (torque) and valve size (horsepower) so the question becomes what's the limit of cfms that the head can produce within a 273 bore. 273/318 heads ported can flow 200-250 cfms at 28" of water which should be good for 400-500 HP. Now what about 340/360 heads? I think you would run out of rpms before you run out of cfms.
So I started to look at other engine builds with similar specs and the best one I found was the 2v 4.6L Ford with a 3.552" bore which is way smaller than (4.5L) 273 3.625" bore. 400 HP 4.6L seem to make it at 6500 rpm the high end of streetable.
As for the lower torque output most people leave out is the effect of gearing has on torque to the ground. 400 lb-ft X (2.50:1 X 3:1) = 3000 lb-ft split between the tires 300 lb-ft X (2.50:1 X 4:1) = 3000 lb-ft same output to the ground.
So any constructive 273 builds or tech especially concerning heads and valves would be welcome. Please and Thanks
