Dartblower
i like 400.............
OK i have read all the comments here and i just come to a conclusion,
Lets be real here,
If he build the 440 it will last for ever no mater what he trow at it remember guys this is no race car here and he don't need 900 HP.
All in all a well built & tuned 440 will give him 450+ HP in a budget with more torque to spare than a 451,
Size is not to significant to take it in consideration,
Weight, neither,
So why take the inconvenience on doing such an engine when you can have what you need in the 440?
Buddy if you are not building a serious race only machine, save the head etches and build your 440 you will be more than happy with your end results and even in the 650 hp range it will last for years to come, if done properly.
Damn, that crank is sexy, lol!NOT that it matters, just TRIVIA,
Most "Strength" issues got covered,
but,
a few things may have been missed in the 400/440 block strength discussions ?
* Although nominal Sonic Test Cylinder Wall dimensions are Identical from Lowdeck to Bigdeck, the SHORTER cylinder wall 400 gets the nod for greater Rigidity by having less unsupported length.
.700" ain't a huge deal, but every little bit helps to maintain Cylinder wall Integrity for sealing.
* 400/440 main caps are identical "outside" dimension, just the 400 is "thicker", due to the smaller hole drilled in it ?
Again, not much,
But,
Sad but true with stuff made outa Detroit "wonder metal' Cast Iron, more mass is better.
Finishes the case for Grinding the 440 Crank Mains DOWN to 400 size and keep the thicker main caps !
I like the 400 Blocks better period.(IMO)
Stronger Mains
Stronger Webs
Stronger Cylinders
If you don't wanna spend the Money to have the 440 Crank Counterweights "Machined", get out yer Angle Grinder, takes about 2-2 1/2 Hrs,
then a Mild Clrc in the Block, easy-peazy if yer handy.
Anything in a 451 under 700 hp I do 'em this way.
x's 2OK i have read all the comments here and i just come to a conclusion,
Lets be real here,
Weight, neither,
Thanks ya'll for all the great information....I too, am considering a 400 for my dart.... i have a couple 383's that i was seriously considering installing, but am convinced now that i will stroke the 74 400 that a friend wants to trade... i was worried about the work involved when installing a BB in my 318 dart, but have really been liking what i see about the 400..... thanks for the info
440 source has a kit to punch a 383 to 496 cubes. All the B.S. about "No replacement for Displacement" is Bologna!! Put a turbo on it and you will have all the torque you will EVER need with Reliability when tuned properly.
ops: I forgot this was a "Budget" build!
im going with a 512 stoker kit from 440source.. and swapping certain parts for other brands.. but 440 is a legend. you should build it
:headbang:
Which do you choose and why? Going into an A body. I have a 440 now that needs rebuilt. I have new pistons and rings for it gaskets, bearings intake and carbs. But everytime I see a 451 i feel like I just got to have one so what would you choose?
