so why do you post this in the racers forum? small block tech would be better ;-))
I use the moroso 8 quart on my 408, see link and picture:
http://www.jegs.com/i/Moroso/710/20730/10002/-1
It´s ok for my application (stock ride height, 80 series front tires), it´s very deep below the k-member. It´s by far the deepest point there, if your ride is lowered not a good choice.
The milodon or kevko pans are better suited for lower cars or if you have to drive "rough" roads
Michael
why two posts about the same thing?
Thanks for info FredS that just what I needed and the picture does it.for street, this is the one I have. Doesn't hang very far below the k-member.
http://www.jegs.com/i/Milodon/697/30940/10002/-1
And a picture to go with the theme
Steff's
6 qt that stays above the AlterKtion.
Very nice screen windage tray and baffles.
Not as cheap as many , but a real nice piece.
http://www.jegs.com/i/Stefs/861/1071/10002/-1
Steff's
