426 small block
DiggerDart
Gaithersburg md
Anyone have any opinion on Indy heads 426 small block stroker engine? Just seems to me that those cylinder was would be paper thin.
How far out did they bore? i thought the hughes 426 kit is only .030?
What is the bore and stroke?
426"/ 440" LA Bracket Master
725 Horsepower @7400 RPM
600 Torque @5500 RPM
Indy 360-1 Intake 1x4
Engine ran with Brad Penn 30WT break in oil
New 59 Degree R3 Water Block
4.100" Bore--4.000" Stroke
Eagle H-Beam Rods
Diamond 14:1 Pistons .984 Pins
Indy 360-1 CNC 245 Alum Heads
2.100 x 1.65, 63cc Chambers
Eagle 4340 Crank 4.00" Int. Balanced
Comp Roller Cam R-2
T & D Needle Bearing Rockers 1.6 x 1.6
.576 / .597---.254 / .262---S108
Sheet Metal Valve Covers
950 DP CFM Holley Carb
Indy Oiling System
MSD Distribuitor
ICH Plug Wires
Engine Internally Balanced
Eagle H-Beam Rods
Comp Roller Cam R-2
Indy Oiling System
MSD Distribuitor
ICH Plug Wires
wow.. that is a bit nuts.. i believe the hughes one is 4.030x4.185.. too lazy to look. I'm hoping to build one for next year
[/URL]
Eagle H-Beam Rods
Comp Roller Cam R-2
Indy Oiling System
MSD Distribuitor
ICH Plug Wires
4.100 with 4" stroke would be 422 or am I wrong
The Indy heads have that reputation…. I think it would be a excellent screamer.
4.180 stroke….
Take a look at @Johnny Mac at blueprint, he has a great stroker.
Your comparing a banana to a cave man club.
He is also asking about cylinder heads more so over the stroker size.
4.185 X 4.18 = 460.54
4.2 X 4.18 = 463.29
4.2 X 4.25 = 471.05
The trick there is a block that can use a 4.2 piston in its bores and finding or making that once available 4.25 sbm crank.
4.180 stroke….
I agree on caveman! But I was thinking OP was contemplating building a stroker?
could be seen ether way I guess? IDK, I seen a question on cylinder heads or the entire package as a whole.
No matter. A banana can be just as painful as club….
Depending on how and where you get hit!
:thumbsup:
If I could do it all over again, I'd have gone with the Indy 360-1 heads/intake in-lieu of the Trick Flows on my 421.
That's not a knock against Trick Flow. Their heads are awesome. The Indy heads are just more capable IMO. I'm seeing guys run high 9s N/A with them. Larger exhaust ports. They're just "gooder" for my application. Just depends on what you're using the car for.
