Brian Hafliger
Hey Brain, what is that intake in the first picture?
I'm viewing this on an I-phone, which isn't the best view.
Indy single plane
Any update?
any update?
Sounds like with an aggressive solid roller & your new version of the RHS heads that combo would be tapping on the 600Hp door! e85 & 14:1 I bet it would pass 600hp
Do you have flow numbers for the CNC RHS head package?
Curious as to how a set of INDY's done up full out would do on the same combo.
Nice work!
Very nice, what was the cam specs?
cool, thanks for sharing! Nice numbers for the cnc´d RHS Heads. I´m pretty interested what the engine can do with the other intake and carb....
Michael
Indy's intake is a very good manifold, so I don't expect much difference at low rpm between the 2 except at very low rpm like 2500 and below. After 3000rpm, the Indy should be ahead and never look back. Unfortunately I won't have those #'s till tomorrow as I'm home playing doctor for my wife and kids...everyone's sick!
I like this build. I noticed that you had torque plates installed for the boring and honing process. I think this is good when you are trying to get cylinders inline as much as posible for as much less power robbing friction you can get.I wonder if it would make a defferance if the block was heated close to normal operating temperture also to allow for the contracting and expanding process. I know a few members will have a ball criticizing this question. Let them have at it.
ok, give them some 0w30 and high octane fuel, they will get well soon ;-))
Michael
awesome build, how much difference do you think the 1 7/8 header made over the step headers
sounds good thanks ou12 my current 416 made 583 hp with steps and I just bought a set of 1 7/8 at a swap meet so I was curious, to see if it would be worth the swap, thanks again
