<<<<<430 cube small block mopar build>>>>>
DJVCUDA
I am trying to separate the two posts - I have the 4.25 post and now i'll be updating this with my build
Here was the original post :
http://www.forabodiesonly.com/mopar/showthread.php?t=128845
Here is the foundation of the build :
a 1979 X block I got about 8 years ago for 100 bux - It was laying around after being built and was never ran. It was clearanced for a 3.79" stroke , aluminum rods, and had w2 heads - i never got the rods, pistons or heads.
Got my rotating assembly together -
BPE's pistons with a -17cc dish for an approx 10.25:1 with a .039 fel pro 1008 head gasket.
the rods are 6.200 long Callies Compstar rods - they have 2" journals and .927 pins - they are nice and light ( 595 grams ) and are plenty strong for my build.
the compstar's are nice - arp 2000 screws and have already been stretched 3 times - the length of the rod has already been polished
like i said they come in at 595 grams +/- 1 gram so they didnt need ot be cleaned up for balancing and the K1 variety is alot heavier at 627 grams
got the parts to the machine shop and started the long process
before -
after shot blasting
On to the Crank -
We checked a number of things to determine the overall quality and condition of the crank. - all measurements were taken at 62 degrees F
1 - straightness - .001
2 - OD of the Mains - 2.4998
3 - OD of the rod journals - 1.9995
4 - Taper of rods and mains - ( worst one ) .0002
5 - Out of round - NA
6 - OD of the snout ( to fit balancer later ) 1.532
7 - Stroke - we came up with 4.125" for all throws except one - that was the 3,4 journal and it was 4.126"
Just another thought when i got home last night I went to callies site and looked at the $1100 dragonslayer crank specs and what they guarantee their cranks to spec out at - here is the quote -
These shafts are machined to the tolerances demanded by today&#8217;s high performance engine builder. Roundness and taper are held to less than .0003 on all rod and main journal diameters. Our final polishing procedures produce excellent load carrying surfaces that ensure extended bearing life and trouble free operation.
So for half the price I got a crank within the spec of the Callies Dragonslayer - not bad in my opinion!
Last thing we checked for was the oiling holes were indeed drilled all the way - and they were!
Didnt want to leave any stone unturned with a new part and have an issue later.
the deck was a mess when we put it on the ROTTLER CNC machine - 12 thousands off on the drivers side and 10 thousands off on the passenger side.
While the deck was flat - and this block was machined at a very reputable shop in the 80's the machinery of today has brought inconsistencies like this to the forefront of modern engine building.
so I had a flat, crooked deck on this sucker. But it will clean up within spec for the rotating assembly.
Speaking about the rotating assembly - It measured out to 1794.6 grams for the bobweight - nice and light!
Weights were consistent for everything :
Rods: +/- 2 grams - 599-601
pistons - +/- 1 gram - 471-472
Just out of curiosity - does anyone know the stock 340 rotating assembly bobweight?
The TCI Rattler had to be fitted to the crank which was 1.532" and the balancer was 2 1/2 thousands smaller - It was honed to fit with a 1 1/2 thou press fit.
The bore centers were checked and while some were not centered correctly the CNC machine bores to where it was supposed to be centered. I think the worst cylinder was 2 thousands off from center to center
After all the cylinders were punched out we decked the block.
Remember I said earlier that the deck was flat - but not square to the deck? well after the first cut you can actually see the difference in out of square...
This shot was taken as the second pass was being made on the deck. - you can clearly see the top of the deck was taller then the bottom, and not it is square to the cylinders.
some chevy guys were asking if this setup cleared the counterweight - apparently in chev land this is a problem...
not in mopar world -
you need .060 clear from the skirt to the counterweight... we have 1.060 miles..lol
last update for now - till saturday -
we are fitting the main caps up and drilled them
these suckers take a long time to fit up perfectly and man are they alot meatier then the standard cap.
the 4 bolts are possible in the x block since the pan rails are filled in that area where they are not in the stock block,.
we mocked up the rotating assembly to see if everything cleared - it did by a mile thanks to the 2" journal.
From left to right :
4.125" Stroke setup - BPE Piston - .927 pin - Compstar 6.200 Rod w/ 2" journal - total weight - 1186g - Total Bobweight - 1749g
4" Cast Stroke setup - KB Piston - .984 pin - SCAT 6.125 rod w/ 2.125" journal - total weight - 1216g - Total Bobweight - 1799 G
3.31" Stroke Setup - Stock Piston - .984 pin - Stock rod - total weight - 1508 - Total Bobweight? over 2000 G I assume?
Anyone know?
OK - a few updates - the heads are at Shady Dell Speed Shop to get the port work done.
The cam selected will require a 954 spring ( double with damper ). This required a tool steel retainer and super 10 degree lock.
The lifters are the COMP 8043 lifters that have the link bars in the front as opposed to the older style 828 lifters. These should require no grinding on the block and since the block is tubed the ability of the lifter to pushrod oil is not going to be used.
Side shot of the lifters.
Have not had much time lately, so not much to update - I have been collecting parts but as far as the bock goes - the 4 bolt mains are done.
The only PIA is the pro-gram supplied studs - if they had been setup for an allen head to run them down like the main studs it would save alot of time.
Had some time for the build this weekend - Got the block one step closer to finished!
We line bored with the CNC machine - and this is setting the cutter up.
Next it was line honed - taking the last bit out of the new caps and set the oil clearances.
We got to work on some other things, but this was the majority of the work that got done this weekend.
I cant wait to see how this turns out. You might have said before but I have forgotten what heads are you gonna be running? And you plan on dynoing it when done?
Thanks - and yes - we are dynoing the motor when done.
RyanJ is porting a set of eddy heads for me right now.
Side by side - next to the competition - you can really see the difference in crank to cam centerlines - the mopar block has a mile compared to the chevy
Getting ready for the final hone - the bottoms of the cylinders needed to be cleaned up - the cut from the bore was sharp at the end and the grinder and sand rolls smoothed it out so that the piston would not scratch when it was all the way down. It will have some rock and the skirts will keep from getting scuffed at that point.
Wow, great job. Is this going to your cuda? Are you planning to feed it with the Ez-Efi?
It is going in my other cuda - I have a 68 fast back that has been sitting around here for awhile.
Thats the plan for now - we'll see how it goes after the motor is done!
Machine work and detail work is great. You have Excellent quality going into it. What do you expect for HP?
i'm shooting for over 500 hp at this point with the eddy heads.
I have a few things to test out to see what the best combo will be.
There is nothing like attention to detail when it comes to rebuilding an engine even moms grocery getter. I've been building engines off and on for over 30 yrs. and I can appreciate someone that knows what they are doing and a machine shop set up with the correct equipment and know how, they are far and few between seems like.
Great build, keep it up.:salute:
Here are a few shots of the heads :
stockers:
Chamber - 2.02 & 1.60 valves are stock eddy
Intake ( Front )
as delivered form Edelbrock - the casting was cleaned up slightly at the factory - they tend to leave depressions where the corners of the ports are -
Intake ( Rear )
you can see some casting it varies from port to port at the seat
RyanJ's stage 4
Chambers -
Loaded with 2.055 & 1.60 Ferrea 6000 series valves
F6114 intake 2.055" X 5.01" X 11/32" Super Flo
F6104 exhaust 1.60" X 5.01" X 11/32" Super Flo
Intake ( Front)
Intake (Rear)
Exhaust
Got to run over to Fonse's tonight -
Comp's 1622 Ultra Pro Magnum Rockers setup nicely on the ported head. They have a mile from the spring and retainer.
Harland Sharp's dont sit over the tip as nice stock. They are close to the springs - too close!
Comp's weigh in a touch lighter then the HS
I thought it was noteworthy to list the weights of the rockers
Comp - total - 163.4 g
- without adjuster - 143.6g
- adjuster - 19.8
HS - Total - 167.0
- Without adjuster - 141.8
- adjuster - 25.2
The Comps have a cup and the HS have a ball.
Interesting illustration there... Did you happen to mock up more than on of each rocker? The Harlands are definately way off.
no I only have 1 HS rocker to test right now
I'm leaning towards the Comps as a result of that.
I can't see how you could use them. I'm guessing it's too early to runa sweep on the Comps? It might just be the picture but even they look too far to the inside to me.
Nice work on the heads. Did you get the flow sheet with them? I'm curious what they did.
THe comps are a ton better then the HS rockers on these heads. The flow sheet is coming with the other head - I asked Ryan to get me a head asap to mock things up.
It will be a bit before I can do a sweep with them.
Got some more progress to report over at Fonse Performance.
Since the block is tubed for soild lifters on one side of the block the other side has to be cut off form oil flow altogether. The Mopar instructions always stated to put a pipe plug in the left side galley - the same result can be achieved by tapping a plugging right above the #1 main.
Another interesting point was the ARP bolt in the #5 main at the oil pump. It was not necessary for a stud in this location so we are using a stock bolt in that location. Here is an ARP bolt we could have used, but if you go this route, you need to double check the thread depth, as the ARP bolt is longer and can bottom out before proper torque is applied.
After all the oil mods were done I got to run solvent through all the oil passages. The brushes removed the last of the debris before another session with the jet wash.
After the jet wash it was rinsed with a pressure washer making sure to get into all the oil passages.
Once more - in the block this time - the COMP 828 Lifters:
and the 8043's
Here is the top end of the motor, Ported ( stage 4) Eddy heads by RyanJ, Eddy Super Victor and a custom Comp solid roller. This is one of a few setups that will be tested out before this gets off the dyno, but this is the one that will be making the big numbers for sure.
That's some beautiful work. I take it that you're doing all this yourself? Awesome.
NO WAY!
I'm learning alot under the watchfull eyes at the shop - One guy has been building small block mopars since the 70's - and probably has forgotten way more then I will know.
In an effort to document the build I have the opportunity to get into the work a bit more then normal.
WHOO HOO!
Got it honed and on a stand today - It was nice to watch an expert take the time to make things perfect today - Neal was taking the time to get absolutely no taper in the bore and have all of them dead on - the dial bore gauge reads to the ten thousands of an inch and i got to inspect the bores before we moved on - well I had nothing to complain about - thats for sure!
The CNC gets things close, but a bore or two were tighter at the top or bottom, ( we are still talking tenths) and Neal got it dead on balls straight!
We had the eddy head on one side and the hone plate on the side we were working on, with the head gaskets in place - the mains were torqued down - This loads the block like it will be when it is assembled.
We used two grits of stone and a plateau hone at the end.
The image was after the jet wash and after I crc'd the machined surfaces.
i dont mean to be picky, but i wouldnt use studs on the main caps for those that are at an angle, but i would use bolts. that way , if you have to change main bearings (for wathever reason) you dont have to remove the studs to get the caps off.
