448with SRs
Member
this is a 440 build Im undertaking with a load of spare's I have. this is a bucks down budget and Im wondering what power it might make
std bore 72 block, the only mods are a 1/2 pick up and .015 off the deck.
std crank with std bearings
std LY rods and std cast flat tops with 1.990 pin height
915 heads with 2.14s and 1.81s 75cc chambers
.020 shim head gaskets
heads are tickled but not what Id call ported, but gasket matched in and ex ports.
.509 cam and dutile rockers with ball/cup push rods.
torker II with a 750 hp carb.
1 7/8 hooker fender exits
windage tray and 7 quart sump
what do you think of that for a budget combo?
also Iv got a t/a 3000 verter and t/a rev patt manual 727 for it
