512 stroker timing ?
71scamp78
terre haute indiana
Got the new 512 low deck stroker running. Just curious on what initial and total timing. It's a 10.3 to 1 compression with tye Trick Flow top end kit. Cam is .600 lift and duration is in the. 240's intake and exhaust. I'm using Don's distributor from 4 seconds flat and his ignition box. Distributor should be close to what I need it a friend's off his stroker similar cam and hp
I’ve not talked to Don directly on his tech support line, but so know enough people who have that I would call for his advice first. Or buy his tuning book. I hear his after sale support on tuning is as good as it gets.
If he did, it should have come with a spec. sheet like this. It has the initial timing spec for that particular distributor’s curve.
If that timing spec doesn’t work for the engine then you’ll have to recurve the distributor.
Easier said then done..not like I have a dyno
I would start at 30 degrees and drive it. Find a nice quiet street you can make a couple test hits on and then slowly advance the timing. Keep advancing until power drops off or you hear pinging and then back it off a couple degrees. BTW- thats total timing
Do you know where your friend set initial and total timing with his engine before you got the distributor from him?
Right now I have it at 16 initial and 34 total..seems it may need more..it pulls pretty hard and starts easy
My 512 was very similar to yours. It was happiest all in with 30degrees. I lost 7hp at 34degrees. All verified via dyno.
Yeah I messed with timing a little yesterday. I went 16 initial and it has 18 in the distributor..seemed better . May try 14 see what it does. What ignition system are you using. I got my dizzy and ignition box off a buddy it was basically new but was set up for his stroker with a little bigger cam. He got it from Don at FBO. It has 18 mechanical and 12 vacuum. I would think it would be really close to what I need..hmm
I have a MSD pro billet distributor and msd blaster coil. What did you end up going with?
It's pretty hard to hear detonation in a HotRod; everything else is louder.
Because of that, I bought a G-tech-ProSS , which is a windshield mounted accelerometer synchronized to time. With this tricky little unit, you can do speed tests at various PowerTiming settings. When the car slows down, she's complaining. Catch it early.
It has some other useful features as well. If you measure out a quarter mile, and follow the prompts, it will calculate your ET and estimate your power and even spit out a downloadable, dyno type graph.
Save your engine, install an accelerometer. Nice tool.
You can even use it to establish a PV tip in, the effectiveness of your vacuum advance, stall timing, etc. I find it to be an excellent tuning aid.
Quick tip;
The more Idle-timing you give it, the more closed your throttle can be made, to maintain the same idle-speed. The more closed the throttle is, the less the fuel that the transfer slots can supply and the more sluggish they will become, which leads to tip-in sags and hesitations. You can enrich the idle with the Idle-Mixture screws, but this will enrich the entire low-speed operation, cuz the idle screws never shut off. And you can overcome the sag with pumpshot.
This is all messed up.
If you have a manual trans;
For a manual trans. I highly recommend as little idle-timing as possible, consistent with a properly sized Transfer Slot exposure.
Too-much idle-timing is easy to spot;
> As the engine picks up Idle power from the timing, the gas pedal will begin to feel like an on/off switch, at tip in. This is especially annoying when going from closed-throttle deceleration to back-on, but at a low throttle opening.
>Sometimes, on deceleration, it can feel like the engine has been shut off.
>Another thing that can happen, with hi-way gears, and in First gear, is that, as the car is forced to drag the rpm below the Neutral IdleSpeed, excessive timing will make the car begin to jump, and the only cure is to toe the clutch. This makes parading as good as impossible.
The cure is simple; with the T-Slot properly sized, just retard the timing until she either quits doing that, or, she stalls in gear while pulling herself, then add back a couple of degrees.
>All of this can be directly traced back to the lack of Transfer Slot exposure, underneath the closed primary throttle valves.
>To satisfy a need for retarded idle-timing, you can run a 2-stage curve that is very fast to some arbitrarily chosen rpm like somewhere between 2000 and 2800, and then slow it down to your "all-in-by such and such" rpm. To get the Part Throttle timing back you can use a fast-acting Vcan that you modify to bring in the missing degrees.
>Another tip for a manual trans, is to map out your advance curve every 200 rpm from idle to about 3600 rpm. You can't know where to go unless you know where you are at.
These tips together should solve all your manual-trans ignition timing problems.
Because of that I bought a G-tech-ProSS , which is a windshield mounted accelerometer synchronized to time. With this tricky little unit, you can do speed tests at various PowerTiming settings. When the car slows down, she's complaining. Catch it early.
It has some other useful features as well. If you measure out a quarter mile, and follow the prompts it will calculate your ET and estimate your power and even spit out a downloadable, dyno type graph.
Never heard of one..sounds like a cool tool
