I went outside and got the duster out from the front lawn because it started raining. I put it in the garage and waited until the rain stopped and when I went back in the garage to bring it back out , I was welcomed by a very big puddle.
at first I thought.. its just the radiator , one of the hoses or the drain....
I checked all the hoses and drain and overflow and everything was dry.
I then backed it out of the garage and took a looksee.
Its leaking from bottom of the water pump/block
right where the waterpump seals to the block , I can't see up there but the bolt and the whole water pump is dry , the only thing wet is the block and really wet.... I got it out there and wait a second and it came pouring out. Most of it is antifreeze/water. some of it is oil though, Im lost.... I know its either the water pump or block. The car has been using a lot of oil, like low ,low .
anybody have any ideas?
