G'day maties;)
pulled a couple plugs, #3 and 5, look good. The engine actually runs very well.
I did back the timing back from 10 to 5 degrees, (vacuum plugged), still revs super well. The engine at that point was warm, but ran the engine at about 1500rpm, AC on, and the needle slooowwwly creeps up to 220, hood shut, squirrel cage fan blowing directly into the radiator. I'm just letting it cool down, then take it for a drive and see what it does. Very frustrating. New fan will be here tomorrow, but I just don't think that's going to remedy the heating at standstill. Perhaps a better radiator?
going to the grocery store now
The radiator I have:
Champion Cooling radiators are tig welded with aircraft grade aluminum. Every radiator comes with a limited lifetime warranty so you can buy with confidence! Product Specifications: Core (H x W): 16.75" x 19" - Overall (H x W): 22.25" x 22.5" - Hose Locations (In x Out): Off-Set Pass x Pass -...
www.ebay.com
