duey_roc
I got the wiring finished the other day. Looking at a wiring diagram earlier and making sure I was careful, I was able to remove a TON of wiring. Horn relay and wiring is gone, so is the ballast resistor wires and all but one coil wire. The one coil wire I left will be the 12V for the HEI distributor I got :supz:
I'm still waiting for my crankshaft and rods from my machine shop :wack: But he did call me and said the crank had to be cut .010" on the main bearings and rod bearings. While I'm waiting, I got the engine bay cleaned, sanded down, and painted with flat black. I'm like my friend Clayton Watts with the 75 Dart Sport. Flat looks clean and simple, and when the 440 down the road is ready to be put in, the engine bay will be done the correct way!
First pic is what it looked like before, second pic is after the aircraft stripper did its job, and the final engine picture is what it looks like now.
