65 vs 63 dart 9" drum front brake hoses, same or different?
Rapid Robert
Lincoln Nebraska
stainless steel front brake hose kit. Mancini has one listed for a 65 dart, wouldn't this be the same for my 63 dart (class rules/must have). Thank you for your time. RR
The difference that I see is that the '63 uses a round fitting for the bracket end
and the '65 uses a hex end/bracket
The lengths are basically the same, just may have to rework the frame bracket a bit.
For what it's worth, the correct hoses for the '63 are available from RockAuto... and probably elsewhere.
for what it's worth, the correct hoses for the '63 are available from RockAuto... and probably elsewhere.
& we're talking stainless steel/direct fit? yes I dont want to have to do any relocation of the frame tabs. EDIT just found the correct direct fit ones at classic auto (with the hex nut). do the round/hex interchange? Hopefully that wont be an issue.
