66 Dart GT Gas Pedal
maldridgeks
Lawrence, KS
Hello. When I purchased my 1966 Dart GT (273 Charger if it matters), the gas pedal was loose from the floor. There is an assembly visible underneath where it was connected with two small bolts, but the part that connected the floor to the pedal was missing. I was able to order a new gas pedal and was sad to see it did not come with the part needed to connect to floor. Anyone know what that part is called and if I can get one? Thank you.
PS - I added a third picture after finding a complete assembly on ebay. I'm curious about purchasing what I circled in white. Again, may just fabricate at this point.
You would benefit to starting a parts wanted thread with your description and photos.
Floor bracket half of the pedal hinge. You may have to buy a whole pedal assembly to get one. It shouldn't be too hard to make, as it's a fairly simple piece.
Thank you. All pedal assemblies I find are of a different style. My pedal attaches at the base of the pedal and then again at the top is presses on the pedal assembly. It is the base that I can't seem to find anywhere. I can fabricate something but figured someone knew where I can purchase new.
Yours is the type I'm talking about. I'm not aware of anybody reproducing that part.
