I am assuming in the car? You should take off the coupler body from the gearbox, install new parts then slide the completed steering shaft into place. Put in roll pin and done. It is splined so it only goes on one way.
Yes it is.....This one?
FYI....be sure to note the position of the coupler on the steering shaft and reinstall it the same way. You can reinstall the coupler two different ways on the shaft and if you choose the wrong alignment, the steering wheel will be upside down. The missing spline on the upper shaft at the steering wheel has to match the missing spline on the coupler.See if this helps. Rebuilding a 1964 Plymouth Steering Coupler Also 1966 dodge dart steering shaft breakdown-Google search.
It helps some, but my coupling box was completely different on the old coupler was set up differently.See if this helps. Rebuilding a 1964 Plymouth Steering Coupler Also 1966 dodge dart steering shaft breakdown-Google search.
