Ya, dem Specialty Products arms are spendy.AutoX will the QA1 UCA's work with the stock 14 inch rim or say a 14 in Crager S/S?
Sorry to step onthe thread.
Me bad
Me bad
Me bad
I would try to replace the 67 Kmember with a 68-72 v-8 piece
Funny you said that, I was just thinking about it. I don't have the ability at home to swap Kmembers, but I know of a shop that could probably do it. Plus I could paint it properly and maybe assemble some of the suspension before it goes in the car. Could you explain more about why the 67 only idler arm setup is so hated?
Last year on Christmas day we drove form Austin to San Antonio while I was down there for vacation...hooked up with a couple of other guys and drove in a 3 car pack at around 100mph the whole way! Good times...1 set of good tires
That’s not uncommon to see down here, but it’s a little unnerving when you’re cruising along in an old car with a 50 year old suspension. Just yesterday a guy was racing a Mustang in his Challenger and they had to have been going over 100Last year on Christmas day we drove form Austin to San Antonio while I was down there for vacation...hooked up with a couple of other guys and drove in a 3 car pack at around 100mph the whole way! Good times...
Just for the hell of it I contacted the Tech Support at QA1 and the Tech Guy saidThey should because you are not going over 4” backspacing on the rims. If you have rear mount factory type calipers check caliper to UCA clearance or ask someone with that combo. When the arm swings out in the back there can be an issue
I know with Hotchkis UCA rear mount factory calipers are an issue
Everyone was go at least 80-85 minimum so it’s not like we were going much faster... plus on Christmas Day the traffic was next to nothingThat’s not uncommon to see down here, but it’s a little unnerving when you’re cruising along in an old car with a 50 year old suspension. Just yesterday a guy was racing a Mustang in his Challenger and they had to have been going over 100
I love that Texas allows us to drive as fast as we need to. I don’t know that I’ve ever seen anyone pulled over for speeding on 35 and it seems rare on the other big roads around here too. The toll road around here is 80mph and some of the rural highways are 85! Hard to imagine there were 55mph limits at one time..Everyone was go at least 80-85 minimum so it’s not like we were going much faster... plus on Christmas Day the traffic was next to nothing
This is what I decided to go with
Qa1 Upper control arms $350
Qa1 strut bars 229
BAC LCA bushings, pivots, boxing plates 190
Hellwig 5906 front / 6907 rear sway bars 494
Proforged lower ball joints 83
Proforged Tie rod ends and sleeves 163
Hotchkis Leaf springs HSS-24385 380
Hotchkis shocks 79020015 520
Firm Feel 1.06 Bars, boots, adjusters 495
Firm Feel Shackles/bushings 135
PST Idler arm 79
Total so far: $3118
Torque boxes and subframe connectors are forthcoming at some point after my welding improves.
Brakes:
Doctor Diff’s Cobra style 13” Disc Brake Kit $1035
15/16 master cylinder
distribution block
front brake lines 125
73- up knuckles 155
Total with brakes: 4433 and by the time I cover all the incidentals that I know will come up, I should be close to 5000.
I think this combination will give me what I'm looking for and more. I expect a firm ride, but not overly harsh.
I'm opting to do all this work myself with the help of the forum. I've never really done suspension work, so it should be an adventure.
Because I didn't realize that there are no 15” performance tires made anymore, I’m abandoning the Cop Wheel idea (still my favorite Mopar look though) and going with 17’s. I really like the American torque thrust original wheels American Racing VN3097765 American Racing VN309 Torq-Thrust Original Vintage Silver Painted Wheels | Summit Racing, but they appear to only come in two flavors for a 17” rim with big bolt pattern: 17 x 7 with 4 in. backspace and 17 x 8 with 4.5 in backspace.
Will the 17 x 7’s work on the front of my car with my suspension combination and a 235/45/17? A 245 would be better...
How about the 17 x 8’s in back? How much tire could I safely put back there?
This is a great list, and is in no way overkill for a good handling street car. If “amateur racers” aren’t running this level of equipment they’re not really trying to be competitive. Which is fine, but they’re not gonna be competitive with less than that.
The original strut rod design with its giant, soft, floppy rubber bushings causes alignment changes. Period. The harder you brake, accelerate and corner the worse these alignment changes become. The factory got away with it because of lousy tires and overall too soft suspension. Throw some 245’s up front with big brakes and that lower control arm will start moving around with the slack in those bushings. That does not provide precise or consistent handling.
And honestly, all the OE replacement rubber bushings out there are trash at the moment. Moog rubber is hot garbage. Their ball joints and tie rod ends aren’t good either. Their production changes have made them a product to avoid. I’ve put 100k street miles on adjustable strut rods on my mopars. And I wouldn’t use factory strut rods on anything meant for the street with decent tires.
There’s fancier stuff out there, I run it on the street and love it. But you don’t need SPC UCA’s or tubular LCA’s for what you want. The rest of the stuff, the sway bars, springs etc are what you need. And really, there isn’t much in the way of cheaper stuff that will do the job. Hellwig is a little cheaper than Hotchkis, but not by much. Most of the things are pretty comparable. You can definitely spend more money than that.
I would run at least 17x8’s all around. In the front with 5.5” of backspace, in the back with around 4.5” if you stay with factory width A-body rear axles. If you go to a B-body 8 3/4 you’ll need more backspace. In the front with 17’s I’d go 245/45/17 like I said before. In the back you can go up to 275/40/17 if you want, you’d need a 17x9 for that. A 245 or 255 would be easier though.
Well everyone is entiled to their opinion. I just express mine alot less snarky.This is a great list, and is in no way overkill for a good handling street car. If “amateur racers” aren’t running this level of equipment they’re not really trying to be competitive. Which is fine, but they’re not gonna be competitive with less than that.
Just in case you run out of budget before you get to the wheels and tires you could throw some Cooper Ultra Touring CS 5 tires on your cop rims... they are a decent modern tire for a daily driver... way better than a cobra or BFG
I picked some up in Canada in the last year...dropped the wheels off at my local tire shop and they called me about 10 days later to come pick them up...they are best tire I have used in that sizeVery cool. But when I went to the copper website they didn’t list that size. Google only popped one person selling them close out
Cooper CS5 Ultra Touring | 225/60R15 | Mavis Discount Tire
There was an issue with 5.25”-5.5” backspacing 17” rims and QA1 UCA’s. The raised area behind the ball joint interferes with inside of rim.
Here:
Qa1 uppers. With 17x8. 67 dart.
I was suggesting running factory strut rods with poly bushings. Then the SPC arms could be used for the added adjustment. And then adjustable strut rods aren’t necessary since you can adjust the UCA so much.
I’m seeing the SPC arms and the QA1’s for same price $349 but you need to buy UBJ’s for the SPC’s ($36/pr Proforged or less $ others on rockauto)
I’m trying to cut to stay within the $5000 budget. $150 here and there...to pay for K-member, rims, and/or rear end.
I run 17x8 5.5” BS with QA1 uppers. I had to do some minor clearancing of the cup, but nothing that concerned me. Outside of that, fit is great.
Sure its a great list and also true is that you can do pretty well with alot less on the street. As far as track time go back to the Trans Am racing series those teams would get amazing handling with very few trick suspension component's .
What to you so long to respond?Actually that thread raises the question of clearance, but only one member said he had actually done it and it worked with minor clearancing of the large QA1 upper cup, and that was with a full 5.5" of backspace.
Adjustable strut rods are necessary, especially with poly or delrin LCA bushings, and the reason has nothing to do with adding caster. I would definitely not use poly strut rod bushings, they're counterproductive. First, you have the issue of the strut rods not being the right length because of the differences between the poly bushings compared to the factory ones at both the LCA and the strut rod. Second, they add binding. The strut rod bushings acts in two different planes. You want them to be stiff under braking and acceleration to keep the LCA from flexing forward and backward, BUT, you don't want them to be stiff when the strut rod is moving up and down with the suspension travel of the LCA. The poly strut rod bushings will actually add binding into the system by resisting the LCA moving up and down with suspension travel. That is why adjustable strut rods are ideal. Not only do they keep the LCA from flexing forward and backward, but they move freely up and down.
And, you can actually make them the right length, which further reduces binding in the suspension. Stock strut rods will NOT be the right length if you're using poly or Delrin LCA bushings. My adjustable strut rods have been adjusted so there's no binding in the range of suspension travel of the LCA. When I was running factory LCA's with poly bushings I can tell you the length of the adjustable strut rods was different than factory (shorter). With the tubular LCA's I run now with Delrin bushings the length was different again to produce free travel on the LCA.
Good grief. The Trans Am cars used all kinds of tricks in their suspension. Only the very basic components remained stock, and even those were modified. They did everything they could within the rules to improve the suspension geometry.
And then, yeah, the rules. What the Trans Am did and didn't do with their suspension was just as much dictated by rules as it was performance. And that was the 70's, so straight back to tire technology too. I love the Trans Am cars, but I wouldn't for a second use them as a blueprint for how to set up suspension for a street car now. Tire technology is better, there are a host of aftermarket parts available that they couldn't use, and frankly if they'd had free reign on suspension components they'd have done different stuff. I mean they acid dipped the chassis' they used. No tricks my foot.![]()
I own some of the original Trans Am engineering design notes. All the suspension parts were moved around. Nothing stock about those.
but I do think you can get dramatically improved handling with a few simple things. I ran half the stuff on that list for 15+ years and it was night and day difference than stock. Drove 80 miles round trip to work over heaviest trafficked stretch of highway in the world (405 sepluveda pass).
the other parts listed are better. No doubt. Just trying to stay in budget and most bang for buck.
I’m afraid we are going to bust past his $5K.
Just when you start going more than 4.5-4.75” backspace, you’re above the ball joint. I don’t like limiting my future rim choices when there are other UCA options for similar price.
what about just running rubber LCA bushing and cutting 3/16” off the rear strut bushing?
The LCA bushings are so thin in these cars, they don’t move around like other makes rubber bushings.
I think the would help road noise and vibration for daily driver too.
also... a 65-67 B-body rear is 2 3/8 wider than an Abody. That’s 1 3/16” wider on each side.
so a 5.5” backspace rim on rear puts you in almost same place as 4.25” backspace rim on A-body rear with LBP axles.
that would save ~$700 over typical LBP Abody 8 3/4.
You can see how things are adding up with the rear end and 17” rims.
This is blowing through your $5k budget
I also don't think we've totally busted his budget. His list was still under $5k, and he went with a 13" brake kit up front.
Questions:
Can one convert a slant six k member to V8? There is a NOS one on Ebay right now
Do B-body 8 3/4s bolt directly into our A-bodies, or do they need to be modified?
Thanks to everyone for the Mopar A-body suspension education
