67 Dart Oil Pressure Gauge
Tag also shows fender mounted turn signals, but are not there and cannot find any
indication the car ever had them. 58 yrs old. Still digging, but so far it all looks good.
It was a special order car.
Would love to see pics of your Hemi Car.
This is My 68 Cuda
Well it is missing all the trim on the belt line which included the fender mounted turn signals like you see on my old 67 GTS convertible...
Work in Progress. Just like Us!!!
My Son and I spent 6 years building Ours.
I cherish the time We spent building The Cuda.
Good Building on Yours.
Thanks for Sharing.
Maybe a fender bender the thing is now wearing other front fenders.
I have a 67 Dart Gt with the Factory Oil Pressure Light. Has anyone switched the light out for
a Factory Gauge?
I just had a thought....
Some modern alternators have a Alternator light rather than a gauge.
How about putting a modified Temp gauge in place of the ammeter for oil pressure with a stock pressure sending unit and adding a light for the alt in the oil light hole.
OR
The light could also be a multi step voltage or Amp gauge with several LEDs behind the red filter. if the center LED is lit its the same as straight up on the alt gauge if the led to the right of center is lit its 10 Amps of charge going to the system if the led to the left is lit its 10 Amps draw on the battery or something like that. It could be externally shunt driven.
volt meter
Full Discharge
a lot of discharge
partial discharge
no charge or discharge
Partial Charge
A lot of charge
Full Charge
