BLUEBYU
TY all for your reply and suggestions!
Well I must say that if you can salvage the ones you have do so. They are not available. I used so far the front weatherstripping to a Jeep Cherokee '91-93 and used both sides. Made them fit so I would not have water seeping inn. I am still trying to find them no luck so far and I have been searching for 4 years now. The Front windshield is still available but the back window isn't. The Front windshield is DW691 Part Number. The weatherstripping for the front and rear are still available. Hard to get but you can still find them. Good Luck. Any other info let me know I have the receipts and could look them up.
Well guys it can only happen to me. Made the trip to websters 1 1/2 hrs. Just to go. Got there and the guy says I don't have your windshield. It was not put on my truck. I flipped because I made sure to call on friday and was told that it was there. Turnes out that they just wanted me to take the one I had and then they would ship it. They did not want to pay for the return of their screw up. So it wound up costing me time and money and no Windshield. I got a tracking number today so hopefully it should be in by friday. I will keep you posted.
People SUCK! :thebirdm:
Received the windshield finally. As we were installing the same realized that the weatherstripping that the glass guy got for me was the wrong one. It is for the same type glass but the one that takes the stainless steel molding around it. So I contacted SGBarracuda for help and he has gotten me a set so I can convert the same over and hopefully this will be the end of the windshield ordeal. Hopefully I should have the car ready to call the tuner so I can take it over to get tuned and then to the road she goes. Got my fingers crossed.
Is 67 all by itself? I thought they were the same up to 76?:cheers:Well Guys I managed to finally finish the rear window and also the front windshield. I end up converting the front to the 68 with the clips and the mouldings. I had no luck finding the front windshield Gasket. Here are some pictures of the Rear and the Front.
I know but then if I do then I would have to either go with a smaller tire or mini tub it and I am just not up to it.Your supposed to LOWER the car, not RAISE it!
