67 twin turbo dart
That's more like it. It appears all sensors are working, but it just isn't starting. To separate fuel and spark issues, what happens if you disconnect the injectors and try a shot of starting fluid?
It starts and runs for a few seconds and stops, then back fires after it stops sometimes not always. But like before I changed how the cam pick up detects and it ran and ran good but not the next day without changing any settings. I did crank the engine and the cam sensor is turning.
And the cam sensor appears to be reading correctly too. This sounds more like a fueling issue. Any chance the fuel pressure is down or you have a clogged filter?
Hello everyone im the one who bought Mad dart's car been a slower process then his figure I'd do an update since I got the car few months ago. Havent done the motor or trans yet been working on the interior first. Put sone insulation on the floor, roof and inside the doors and quarter window area, installed and have mostn of it wired a EZwiring kit, adding power window to the doors bit thats it, have the motor and regulators just waiting till I get the front and rear glass reinstalled after I do the head liner. But front to rear lights are done waiting for the custom dash panel to be made, have the front suspension in the car just need to do the rear end.got some new wheels for the front since adding wilwoods front brakes the 14s wouldnt clear. Ill update more as I go, just did the carpet kit today letting it sit. Wheels are coys 15x6
Digging the wheel choice.
Got it running, for now. Took it out for a drive. It actually started 3 time in a row. Fuel pressure was a little low that's been adjusted back up to 43. With just the pump running I had it adjusted to 43psi but with a load it dropped. Brand new fuel filters. Hopefully fingers crossed it continues to run. Funny thing is with the new fuel regulator the cars running way rich now lol got on it and went to 10. Figured I'd have to tune with the new set up
Good news started up second try, ran good drove it over to my parents house to help with some yard work. Drove back no issues. Will see how the weather goes when good will go out to a spot that the owner doesn't care about cars doing test hits, safely of course.
