strang3majik
I think I know what everyone is going to say, but, looking to see a discussion that might sway my thinking one way or the other.
I have a 67 Valiant two door that I'm building pretty much from the ground up. Important bit of info, I'm a college student working part time, so funding is limited.
But, I have a Dana 60 and an a833 four speed I am definitely using...what I am unsure of is engine choice.
I have a 1975 30k mile 440 sitting in the garage on a stand. I have a set of 915 heads and would like to pick up a set of standard bore 67-69 factory pistons to bump the compression up as well as a steel crank. I have a set of B-body HP manifolds I could use (buddy of mine had a set on his a-body and said they barely cleared the steering shaft on an RB engine, but fit)...
anyway, I have this 440 here. I'll need to get mounts, bell housing, flywheel (I'd use the 10.5" one I have), clutch linkage, and other misc assorted bits.
Also sitting in the same garage is a 5.7 Hemi freshly pulled from a totaled 03 Dodge Ram. It is just a long block with no accessories.
If I used this it would stay carbureted, though with one of those Hemi boxes for the coils.
I would need to buy mounts, bellhousing, flywheel, headers, intake, MSD Hemi box, clutch linkage or hydraulic setup, cam (wouldn't want it stock setup), water pump/alternator, and other misc bits. Wouldn't mind throwing a set of rings and bearings in too as well as headgaskets just for piece of mind. Truck had 120k on it.
I'm running manual steering regardless. I also have a slant 6 k-frame in the car now...I know they make big block conversion mounts, not sure if they make hemi mounts for the /6 k-frame.
So...which would be the better way to go?
My thought as of now, I'd love to throw the hemi in there, but, I feel it may be out of my financial reach even though I already have the engine, so the 440 seems more feasible. But maybe I'm over simplifying the 440 swap and the cost difference won't be that drastic.
Thoughts? Input? Criticisms?
