Ball bat fixes it.Oooofff! I did the same thing when I installed my wheels. Had to roll the lip over and trim the corner to clear.
Might be something to look into before trimming.
I remember reading a thread about someone having the same rubbing issue on a Duster here years ago. It was just a slight rub, so they either shortened or extended the brace from the fender to the bumper bracket to fix it. Don't remember which way though!Might be something to look into before trimming.
Yep!
Well, back to the waiting game.
Ordered 2 17x8" front wheels from a 94-98 mustang bullitt edition which are similar to the torque thrust II wheels I have currently, only these have +30mm offset which will cover my mistake of forgetting the track increase on the new disc brake kit.
From what I can tell, I'll need to do a couple mods to the rear wheels to match them up:
1) need to paint the rear spokes with a clear so they match the gloss shine of the new fronts
2) need to figure a creative way to match the center caps on the back to the front. Fronts have a flat cap style that has a black emblem in the center(see photo). Rear's have the standard raised polished cup style from American Racing. Looks like there's a few places online that sell "flat" caps that match the mounting hole locations so I might be able to at least get the cap profiles to match.
Good point. If that ends up being the worst issue im ok with that. I'll let you all know when they get hereBe aware that the nose of the hub will probably interfere with the center cap on those wheels and make it so you can't run them. Maybe not, but seems to a common problem.
Ahh man. Yeah I was worried about the center bore size - the site doesn't even list the diameter. Thanks man appreciate the heads up. Sucks to give back another 9.5mm of offset - Existing wheels from 0 to new wheels with +30..... minus the spacer -9.5mm = ~20mm offset net. Torque Thrust IIs do have a +25 offset option but they weren't available to ship until May.... and I didn't wanna wait that long for a new front set of wheels. Hopefully +20 is enough for my existing 225/50/17 tires to work without too much fuss.As DionR mentioned, the bearing cap on the front hub will stick out past the flat face of the wheel. Also, you’ll have to run a 3/8” spacer on the front to clear the front hub or else have a machine shop hog out the center register of the wheel or taper down the nose of the hub. I opted to run the 3/8 spacer on mine.
You should be fine with the spacer and your 225/50’s. I was running the spacer and 245/45/17’s and had the car sitting as low as I could get it without bottoming out regularly.Ahh man. Yeah I was worried about the center bore size - the site doesn't even list the diameter. Thanks man appreciate the heads up. Sucks to give back another 9.5mm of offset - Existing wheels from 0 to new wheels with +30..... minus the spacer -9.5mm = ~20mm offset net. Torque Thrust IIs do have a +25 offset option but they weren't available to ship until May.... and I didn't wanna wait that long for a new front set of wheels. Hopefully +20 is enough for my existing 225/50/17 tires to work without too much fuss.
Looks so nice!Also, here’s an idea you can use for center caps. I have the caps to put on my wheels, I just haven’t ever gotten it done yet.
Ooohhh. I completely missed the fact that you’re running cobra brakes. In that case, yes, you’re good to go! The spacer (or opening up the bore) is required on the 73+ factory discs.Dry fitting the new mustang bullitt OE mustang rim. It doesn’t look like I need to bore out the center. Fits flush with the hub. Am I missing something?
Again the disc brakes are the dr diff cobra kit upgrade with BBP. Outside of the caps not fitting am I good to go?
@DionR I think you're right... not sure what I can do about that. Before the rotor goes on, the length is pretty short to begin with, and these rims have a pretty thick mounting surface as well. I guess I could swap the bolts for longer? Unless there's some magic to the taper angle ideal for these wheels. The OE wheel site didn't have any detail on the taper to the lug nuts mount surface. Ideally i'd love another half an inch of grab.
I'm gonna be delayed anyway - have to ship my rear BBP 7 1/4 axles back to Dr Diff. Since these are a new product, Cass found a safety concern. "The axle may slowly walk out of the wheel bearing due to an insufficient interference fit between the locking collar and the axle journal. To be on the safe side, I should Email you a UPS return shipping label and replace the lock ring."
So while that's in shipment I'll be troubleshooting the front lug nuts and trying to tune the carb a bit. Gotta hook up the vacuum gauge and fidget with the fuel adjustments till it's a bit kinder at idle.
At SOME point i'll take my wife out on a date with this beast. She's been battling thyroid cancer for 7 years and definitely deserves a night out without the high pitch screaming from our 3 kids.
Yeah i have his 13" cobra front kit. No spacer used on the front or back. The rears mount great still but that might be because they're on the torq thrust II's which have a thinner wheel mount thickness than the mustang OE wheels.Since you are talking to Cass anyways, I would talk to him about the studs. Assuming I am correct in remembering that you are running his front kit. Did you end up with a spacer on the hub?
Probably worth bring this up even if they aren't using his front brakes. Maybe he can make sure the rear ones don't have the same issue, unless you have already confirmed it isn't a problem.
