SputnikOne
Here's the rest
Why is this confusing?Touching alternator output lug to the engine block for ground while it's not running gives me 12.45 volts, which is alittle confusing
Yeah, I think the alternator is outputting 12.45 ish volts, which is pretty low, but it would explain why the battery isn't quite dead yet. Got 12.45 volts when touching output to ground from the alternator, and revving the engine seems to make the ammeter move *the tiniest* amount towards charging.
That's the A1 circuitThis connector specifically is concerning, anyone know where it goes? It's a red wire by the brake booster
What big splice? I'm not sure I see what you're talking about, you think it's bypassed on the power cable but the field cables are messed up?
The 'engine connector' is a common location for problems to develop on the cars that have them.
The engine connector is a common problem location. You can take advantage of it for diagnosis but its main function according to @RedFish was to make production easier. Earlier cars don't have it.I'm not sure I see what you're talking about, you think it's bypassed on the power cable but the field cables are messed up?
Do the steps as I laid them out. This will test the alternator. Once that is known to work, that shows the blue wire TO the alternator (the field power supply) and the alternator itself works, along with the charge path back to the battery.So, what do you recommend to test the alternator and the VR?
