j par
It's definitely putting the carriage way way before the horse but I would have probably just bought $180 cheap Summit headers..Nice! That’ll do!
That will be the easiest header install you have ever done, if you do this.^^^^after all that work I fell asleep in my chair and woke up and checked Craigslist and a pair of headman headers popped up brand new for $80...
$240 on summit...
View attachment 1715718810 View attachment 1715718811
SCORE!!!...![]()
.. FINALLY...
...$$$$...You will absolutely have to drill those rivets. I think a whole new assembly is available at rock auto. An even better way to go would be with Jungle Jim’s Fabrications. He makes a real nice mount/ bushing setup.
.... LOL...Finished picking the frame clean and loading it on my trailer...
The only thing I couldn't get out was the bushings for the front leaf springs...
I'm thinking I may have to resort to grinding the rivets off and pressing them out on my press..
View attachment 1715721065 View attachment 1715721066 View attachment 1715721068
Since I can take those off and put those in my press I probably will try pressing them out first before buying new ones...
yes the frames up on my trailer and that part is actually sticking off the back of the trailer so it will be a walk up to it situation. I'll probably start with my cut off wheel and see if I can't take a slice sideways at it...I ground a bunch of those rivets last fall laying under The Yeller Dodge. I used some really aggressive carbides I dug out of the dumpster at work. I got absolutely covered with grindings. At least you have a bare frame!
Did I mention that I HATE frame rivets?
Didn't have a big enough socket to get the d60 pinion off
I appreciate that! I'm now in a bit of a tailspend cuz I just got a call from a guy that might have new axles lift kit the whole nine yards for probably cheaper than I can get all this stuff done for...What size is it? I have sockets going up to about 2.5" as well as combination wrenches that are about the same.
