Have any of you swapped a 9" into an early A body? If so did you use a hybrid U-joint to mate the Ford rear to the Mopar shaft or get a new end put on the drive shaft or......? So far I can't locate a U-joint that will do the trick. I still have the PB904 and right now plan to keep it.
Any and all info appreciated.
Brad
Brad
