95-99 gtp38
m880
florida
Has anyone on here used one on a small block mopar yet and how did it work...I had a 95 f-250 powerstroke and bought a good used turbo for back-up but no longer have the truck and thinking of putting it to use..any feed back appreciated other than negative crap,you can keep that and bottle it up........
I haven't seen one on a Mopar yet but they do put them on Chevy 350's. Not sure how good they work, but I would assume you would have to overdrive it to get any amount of boost on a 360.
Jack
Here's the specs
STOCK GARRETT TP38
Compressor wheel inducer diameter: 59.87 mm (60 mm)
Compressor wheel exducer diameter: 80 mm
Compressor housing A/R: 1.10
Turbine wheel inducer diameter: 76.2 mm
Turbine wheel exducer diameter: 69.84 mm (70 mm)
Turbine housing A/R: 1.15
