A 1974 Duster - My 2nd one, 41 years later!
Thanks Mike!
Sireland, I think it was a Goodmark. If I were to do it again, I would get an AMD panel.
That is what I bought, for the money they are ok.
My next project is getting AMD, I am not even going to try to go cheap on it, not worth the extra time.
If your going to swap to the earlier rear bumper you should weld in the filler piece that is missing behind the bumpers on the 74 up's You wont be able to nicely fix that later.
Love everything else! Nearly exactly what I want to do to my 74
I will look into that Jamakin, thanks for the tip. I will be ordering 73' fiberglass bumpers front and back. Maybe I better order them now...if welding is needed, better do that before I go any further with paint.
Just got the Helwig bar bolted in. Had to modify...their instructions were not exactly as what needed to be done to getting it installed on my car.
IMG_4465 by Alexl5280, on Flickr
IMG_4466 by Alexl5280, on Flickr
That is odd, what I remember when installing the bars on my car, the fronts were easy, the rears were a little harder.
Ordering AAR rear fiberglass bumper so I can deal with fitment as Jamakin pointed out, now is the time. I refuse to put those god awful heavy boat anchor bumpers back on. I will have to fab up some mounts, no biggie. The OEM shock absorber rear bumper mounts were completely removed.
AAR bumpers to be painted in Sassy Green......or Black...what do you think is better???
Bumper, Duster, 1970-1976, rear | AAR Quality Fiberglass Reproductions
Bumper, Duster, 1973-1976, front | AAR Quality Fiberglass Reproductions
I didn't do too much today. Started the line lock-roll control install. Figuring out where button goes with a pistol grip shifter is a challenge. I may be going with a different shifter with incorporated line lock button. Started taping off the window areas for spraying the 2k primer. Fiberglass bumpers on the way.
IMG_4474 by Alexl5280, on Flickr
IMG_4475 by Alexl5280, on Flickr
I started spraying the Kirker Perfect Prime 2K primer yesterday. Never shot any 2K before so I had to figure out how to spray it. I'll get it. It seems like spraying it at 29-30 psi at the gun it goes on wet and lays down very nicely. Here is the 2nd coat about an hour after I sprayed it. The 1st coat was guide coated and blocked with 320. I used 4:1:1 mixture, paint/activator/reducer. My primer gun is a Iwata AZ3 with a 1.8 tip.
IMG_4494 by Alexl5280, on Flickr
IMG_4493 by Alexl5280, on Flickr
IMG_4492 by Alexl5280, on Flickr
Did the hood scoop come with a template or do you just have to lay it out the best you can ? Thinking about gitting one.
Jaws tip: Tape right on the center body line, spray above it, 2K prime and block to tape, then reverse it and do the same thing from the bottom up. Defines the center body line. So I gave it a go! Top side in 2K. Two good coats.
IMG_4505 by Alexl5280, on Flickr
IMG_4504 by Alexl5280, on Flickr
IMG_4508 by Alexl5280, on Flickr
IMG_4507 by Alexl5280, on Flickr
Sprayed another coat on the passenger side upper, moving around the car with the 2K
IMG_4515 by Alexl5280, on Flickr
1st coat drivers side upper done, roof done....I ran out of paint, missed the center of the cowl. More paint ordered. Shot the last of the guide coat can, more ordered.
IMG_4519 by Alexl5280, on Flickr
IMG_4520 by Alexl5280, on Flickr
View attachment 1715081023IMG_4474 by Alexl5280, on Flickr
View attachment 1715081024IMG_4475 by Alexl5280, on Flickr
Are you talking about something like this?
https://m.summitracing.com/parts/hu...DzZy_FK9fhetaY4YqDqyDOizkfCfxgiBoCRAgQAvD_BwE
