Thanks Rod! Those look like the gaskets I need. I got the intake, separated the halfs and found an old beer/soda case box cut for a gasket. Which works, but .....
Here is a list of the items I bought, keep in mind I am going on information that yellowrose gave earlier on thread which he states will work and I have no reason not to believe him. Once i receive the intake top I will make sure of the match to my old base and post pics. It sure looks like the correct one. Do not go by the picture of the intake as it is not the correct picture. They have a disclaimer that the pic is only a file pic and may not be representative of the actual part. I called them last night again to make sure and was told it is not the correct pic for this part.![]()
EDL-7032![]()
(Mfr. #: 7032)
EDL-6950![]()
Hope this helps. Im excited because I want to mount my carbs sideways and the original top will not allow that. Also this may make the total height a little less which will be a good thing as well.![]()
Rod![]()
Got home late last night from a weekend vacation to find the new manifold had arrived. Looks to be at least 2" shorter then the original and this morning I got up early tinder if it would fit. I'm happy to say it has the identical footprint of the base and it actually had gaskets and bolts come with it. Tonight I will bolt everything together and start working on some linkage. I will need to make a base pivot stand but I should have everything else. Pics will be coming later tonight! I'm also thinking about powder coating both top and bottom so the aluminum matches? What are your thoughts on doing that? Again, thanks to yellow rose for this idea. I would have never thought to use a SB Chevy top!
Rod
Here are some pics of the intake top both separate and mounted.
You can see the newer one is at least 2 1/2" shorter then the original one.
Will need to find or make a lower mounting pivot. My linkage kit did not come with one but it looks like its a custom make type of job.
Also will probably need to get another air cleaner assembly that fits better.
Well yellow rose, once again you've been a big help. I called "good vibration motorsports" and now have a base heading my way. The only problem is there is no listing for a small block dodge. His only listing for a mopar was for a 440 and that one requires an adaptor. I had him send both, I figured I could make it work with some fabrication! I had never heard of that company. So again thank you for your help.
Rod
... I'm also thinking about powder coating both top and bottom so the aluminum matches? What are your thoughts on doing that? ...
Kisses to the "Chick!"
Thanks.
FWIW, test fit your stuff before power coating.
