Old Man Mopar
Righteous Dude
Some more early fab pics - tailight panel & trunk
Holy Cow Sky...I see how you rate.....
already got the die-cast replica of your hot rod by Bro John!...
skypower, the pic of the lower shock mount (post#704) looks to be below the scrub line... please tell me I'm wrong.
I've got exactly the correct rear wheels and tires (elsewhere)
to make one of these like Skypower's. It's a Hemi.
Got a fresh set of these M/T's (in this exact size - 315/60R-15)
with 15x8.5 gray centered Torq-Thrust D's and matching 15x4.5
fronts with 205/75R-15's.
All are here....just have to get them mounted and balanced.
An alternative look to the Cragar set with the 315/60R-15 BFG
Drag Radials.
Seems to be all Drag Radials, not just M/T, and has to do with launchDid you ask about how those tires work with a stick shift car?
Now I see O B Whan thanks for the info.Seems to be all Drag Radials, not just M/T, and has to do with launch
techniques when racing on the strip.
Quoted from an on-line forum:
"Something has to slip when you launch a car.
Either a torque converter, a clutch, or a tire (or a combination of two).
The problem is that D/R do not seem to like being the part that slips,
they don't tend to recover like a slick or bias DOT tire. If the tire is not
slipping the clutch is."
Here is a great article on Drag Radials from MoparMax online magazine:
http://www.moparmax.com/tech/2008/iii_7-tire-1.html
1973is that your red vega gt in the garage/driveway?...what year was that?
Theres a All Mopar Show next Sunday June 26th at Summit Racing in case you want something to do ...it's only 1 1/2 miles from the house and I would supply the cold beer and hamburgers plus maybe you could give me some pointers on the Duster....this offer is good for you to Mark, sorry about your plumbing problem
Noted.12 years and counting.............................. [-o<
Noted.
