A/C Heater box interchange question.
It should fit if your going heater/ac to heater/ac box. If your trying to add a/c it won't work as the firewall is stamped and drilled totally different with just heat.
If my memory serves correct, the heater core for 75 and 76 model has a different part number from others and doesn't interchange. Does that mean the tubes and placement is different ? I don't know. Maybe the difference is in the case.
Just a point to research I guess. Good luck
