Adam's Scamp
Just about there AdamR,
This has been a great ride to watch you build.:toothy8:
Enjoy the loose end, and hope all go's smooth.:drinkers:
beautiful adam, I hope my will turn out half as well. How long have you been at redoing the scamp?
He has been on it a many moon's.
Butt are we ever Dun.
They are never done but just once I'd like to be able to formulate a cohesive and logical step by step plan for performance improvements. I've never been disciplined enough to do that yet though. I'm the first to throw in a new converter, rear gears and a camshaft and be flat footing it on the track the very next test and tune day. lol
I do like your car though, you are gonna stick with steel wheels and poverty caps right?
You are gonna stick with steel wheels and poverty caps right .
Poverty caps !!! lol Thats a new one on me. Poverty caps:toothy10:
I think so. I think its going to get some black cop car rims and some 275-50-15 drag radials out back.
That would look bitchin'. I'd use a flat hood too, no scoop. They attract too much attention.
I'm actually going to try and run a flat hood on my Scamp. I know without the spacer it will fit and if it's too fast that will slow it down about a 0.15.
yea i know never done, but done to a point where it is satisfyingly drivable is what i meant.
I understand what you mean it is nice to get them that far.8)
I was just throwing poop at adamR.:bootysha:
Its not getting a scoop. Its also still auto on the column (reverse patern valve body should be fun) and a bench seat.
Well the motor is back apart to so I can find the reason for water leaking past the gaskets. It may very well stay apart for a while. I want a street car and the 11:1 compression and huge solid cam are going to suck. I would like to swap to a set of Edelbrock RPM 340 head wich will drop compression down to 10.35:1 plus the aluminum should help.
I also want to swap to a more street friendly cam. I was looking at the Lunati Voodoo 274. I 'll probably keep my LD340 and Thermoquad.
Im also going to run a smaller 2.5" exhaust and loose the manual valve body.
So know I have doubled the length of this build up and will be broke for the next 3 years. I hate this hobby. I just want to drive the thing all ready.
yeah since you get a point of compression to play with on aluminum heads, that would be the way to go. what cam is in there again? a comp xtreme energy or lunati are good choices. hope the leaks quit.
The leak has to do with the intake not fitting right. The heads have been milled down to 60ccs to bring compression to 11:1 with stock 10.5:1 high comp 340 type pistons. When I bought the motor it had a Eddy Victor on it that I sold and replaced with ny LD340. Thats when I found out how much the heads and block have been milled. No it doesnt fit well and I dont want to cut this poor LD340 up if I plan on switching head later anyways.
The cam right now is a Crower solid 260/265 @.050" .580" on a 108LSA. The cam made the torque curve peak at 5400rpms. A little high for the street.
Got a nice set of door panel from 360Scamp, Thanks again ! Interior is done with the exception of a pair of front arm rests and the nut and clip that hold the drivers mirror remote in place !
Good snag AdamR. they look perfect from here.
I bet you was glad to receive them!! and get them in.
:thumbup::thumbup: No problem man, Im just glad to see them go to use I was about 2 weeks from junking them and then I remembered you needed some. I will see if I can't find the arm rests this weekend if I go out to the shop.
That blanket is a gas! A bag of groceries would look appropriate sitting on the seat. Does your car have the locking steering column?
Got my 3/8" pre bent fuel line from Firm Feel today. Kinda a PITA to install but better then bending it my self.
Also the reason for the water leaking from my intake, Seems I forgot to use some sealer around the water passages. Oops. Not going to put it back together yet though. This motor belongs in a dedicated race car so Im going to try and find it a new home and find something milder.
Scored the needed rallye from MtNemo so now I have the front set. The rear will get some 15X7s from summit racing and Ill wrap them up with some new Radial T/As.
Im also going to freshen up the brakes and lines and then just drive the thing as much as possible.
The blanket I have had for years. It was covering my motor before I even bought the car. I then relised it matched the car well and hid the huge rip in the seat.
Have you had a column lock on you before ?
It also looks like my 340 is going to a new home in PA and is being replaced by a fresh 360 with a Hyd roller cam and Magnum R/T heads.
You should keep the blanket even if you get the seat fixed.
I haven`t had a column lock on me before but have heard horror stories!
A 360 should make a nice street motor with plenty of get up and the 340 can go do what it was built for. Didn`t you have that engine (the 340) installed in the car already? That sucks having to pull it again!
Yes, I just dropped the motor in but had to take it a part to fix a coolant leak. Not to bad to pull it with the TTIs.
