AdamR
Big Member
I got out of work nice and early today so I went to clean up the Scamp a little bit.
The only rust on the car, Just surface. I should fix it soon though.
This explains why the car is so clean for 36 years old.
The window regulator needs to be fixed. Im hoping the missing bolts are the problem but most likely some one took them out to remove the window and never finished.
Anyone know what this second pipe is ? Some type of vent ?
Im going to start cleaning up the engine compartment more. I need a new mater cylinder, so I'll remove that and the wiring to make it easier to clean. I'm also going to switch to manual sterring so the power box can come out. Im not doing any of this till I have the parts though.
Then Its off to the interior, new carpet, front seat cover and a 8 point roll bar, a few odds and ends is all it needs.
The only thing Im doing to the outside of the car is either replace the hood with a fiberglass bolt on 6 pack hood or buy a 3" tall Hemi scoop for the hood thats on the car. Id rather not cut the hood though even though its not original.
