Barracuda Bum
Member
I have a 68 Barracuda that came without the light package from the factory. I'd like to add it. I have already installed a trunk light in the vehicle, that was a piece of cake.
So I'm looking to add a light for the Ignition Key, Glove box, and a Map Light. I believe I have all the hardware and wiring harness to do the job, but after looking under the dash I didnt see any extra electrical connectors to tap into to do the job.
So my first question is would there have been 2 different under dash wiring harnesses from Ma Mopar depending on if you ordered up the light package or not?
If the same harness is used for both where would I tap into the harness to get power to these 3 lights?
I did see a post here saying that the glove box light should be run off the cigarette lighter circuit but there's no extra plug there to tap into.
I have not come across yet a wiring diagram for a 68 Barracuda that shows the light package option. Any electrical diagram help would be greatly appreciated!
Thanks in advance for your help.
