Aug 18, 2011 #1 L ltrripp11 Well-Known Member Joined Jan 23, 2006 Messages 107 Reaction score 2 anyone know the proper way to "burp" the cooling system for any potential air pockets? thanks..
Aug 18, 2011 #2 Bad Sport HALF A BUBBLE OFF Staff member Legendary Member Joined Jun 12, 2010 Messages 44,803 Reaction score 34,762 Location The Wolverine State You can drill a small hole in the flat metal around the T stat, and put the front tires up on ramps when filling.
Aug 18, 2011 #3 D DJVCUDA Well-Known Member Joined May 26, 2004 Messages 1,075 Reaction score 35 I jack my car up in the front when filling - always works ! I also jack up the back when draining...
Aug 18, 2011 #4 67Dart273 FABO Gold Member FABO Gold Member Joined Oct 14, 2010 Messages 62,697 Reaction score 37,144 Location Idaho I just leave the manifold heater fitting disconnected, if possible unhook the hose at the heater so it's a "taller" port
Aug 18, 2011 #5 vitamindart Well-Known Member Joined Jun 11, 2010 Messages 1,535 Reaction score 663 Location Vernon,Wisconsin on my big block becauses there were no heater hoses i would pull a plug from the water pump housing. plus drilled the holes in the t stat...
Aug 30, 2011 #6 L ltrripp11 Well-Known Member Joined Jan 23, 2006 Messages 107 Reaction score 2 thanks all...
