so let me get this one straight. 95% of the racers in this country are stupid and don't know how to tune a carb?
pretty hard to argue with me on this one since i quoted your stupid *** comment again. but you will try to argue it again.
wonder who the other 5% are that can tune a carb?
which one are you in? stupid 95% or the elite 5%?
Let me try this again because you are so thick headed. I’m saying when someone goes from gas to alcohol and picks up a huge amount of ET, it’s a sure sign that their gas tune up was JUNK. And yes, from DECADES of going to the track I can tell you most guys run their gas tune ups way too fat. With gasoline you just can’t do that. Alcohol makes it so you can run them fat and it won’t hurt the power. Simple as that.
And yes, 95% of the dudes at the track can’t read a spark plug and half of them can’t use a timing light. That’s just a simple fact.
So take that any way you want, but I suspect you are one of the idiots that switched to alcohol and picked up way more that you should have because your gas tune was garbage. That’s why the truth hurts. You are one of “them” and I’ve me way too many “you’s” to give a single **** want you think.
BTW my other favorite bullshit lie about alcohol is it runs cooler. And guys run their junk so pig rich on alcohol they cool down on the return road. That’s a sure sign that they can’t tune gasoline and they won’t put enough radiator and pump on the car to cool it correctly.
Many times I was paid to consult on alcohol stuff. And every single time they had found big ET drops with alcohol. And every time (for the ones who kept notes) I could go back and look at what they were doing and show them they were off on their gas tune up.
Been to the dyno many times for the same thing. Injection was my favorite, as you can go from alcohol to gas and back really easy. And never once, not once did I find more than 2% more power with alcohol. Not once. Ever. But what I did do was switch back to gasoline, make a couple of changes (usually I increased the idle bypass pressure, decreased the nozzle size several thousandths Les than what they had on gas and I hooked up at least one more bypass) and their gas power numbers came up.
Most of these guys weren’t ducks. Most of them kept meticulous notes so it was easy to go back to what they had. Most were pig rich and slow on timing.
So yes, if your little feeling got hurt that’s on you. I can guess you are the 95%. Revel in it. You appear to enjoy it.
