Order of parts at top center
T shaped piece with hole that keeps the shoes in place.
Cable end with its flat side toward that T shaped piece.
Longer yellow spring ( the cable guide should have a tiny neck to center it in the hole.
Hold it in place with one hand while attacheing the spring on the top post.
Then the shorter upper return spring.
If the pin is filled the yellow spring will hold the cable guide flat against the shoe.
One wouldn't think the tiny neck on the cable guide is important but...
If it fails the guide drops which lets the adjust paw drop.
A hardened steel thrust washer in the free end of the adjuster is just as important as any other tiny member of the assembly.
A dab of lithium grease there is OK but dont apply grease to the adjusters threaded parts.
When its all correct you would be able to put 4 fingers on the shoe lining ( about 4:00 postion ) pull the cable toward 5:00 with your thumb and operate the adjuster.
