Dartfreak75
Restore it, Dont part it!
Does it matter where you put the hole? Or do you just center it in the plug?
I centered the hole.Does it matter where you put the hole? Or do you just center it in the plug?
Well thanks but like I said, this is just a refreshing. I don’t call this “My build.”But we know it will be done right. Ready to watch a master at work.
@rumblefish360
Hey man what ya using for gaskets? If your interested i have a set of new fel pro perma torque head and intake gaskets your more than welcome to have. Not sure if you need custom ones or not. Arent crazy expensive but will save a little money and they are sitting in the house doing nothing just begging to be used on a engine. Also i wish i would of caught this sooner, i got a new set of freeze plugs id send ya too lol
Just figure id offer, didnt know if you were on a budget build or not.
Head gasket: 8553PT
Intake gasket: 90109-1
Lemme know man, i deff will be tuning in.
Well sure! I’ll send ya some bucks for them. PM me with your “Extra parts list” please.
Ya! Tell me about it! UGH! I’ve been slowed by a few things and the mess I unknowingly created will have to be straightened out after I get the 2nd 340 back. When ever he is done. There’s no rush for me. He isn’t jammed up. Only 11 engines in his shop right now.You're not done yet? lol
Glad it arrived unbent lol, i tried to find the thickest cardboard i could.
Keep us posted!
Rings break from detonation.The rings that broke, is unknown and I didn’t inspect it any further than seeing it was broken and taking a two point shot into the garbage.
Likely cause is over revving the engine. The rods on the broken piston rings and one crank journal had bearing issues. The crank is at the crank house now waiting it’s turn. The block is being cleaned & inspected to be honed.
And another handy tip for you novice engine builders.
This is a “sacrificial” 6 inch 3/8 drive extension. It is a good fit for the plugs at the front of the block. A little more Indian head gasket and drive them in a bit. They should be counter sunk.
There is also a trick mod to be done here later. A small drill hole on the driver side plug to spray some oil onto the timing chain for that little extra oil insurance that can only help during high rpm runs. A drilled a 3/32 hole in the plug. I think that was a bit big when I was done. Installed now. Coffee break.... LOL
(Not that this engine will, maybe, I think. OH! I don’t know....)
Never had that problem.I don't put squares in round holes because it puts four point pressure and distorts the circle out of round. To each his own.
