another tire/wheel question...
fastback68cuda
SO-CAL
is anyone running this wheel on a 67-69 barracuda? i have large bolt pattern all around with drums in the rear and 74 dart disks up front.
can i expect clearance problems with the backspacing? what size tire can i run in front? rear?
Size 15x7"
Bolt Pattern 5x4.5"
Backspace 4"
Center Bore 72.6mm
thanks in advance for the help,
robert
I`m running 15x7`s with 4.25 backspacing without any problems. 4" bolt circle. Tires are 255/60-15`s. Fronts are 15x6 with 4" backspacing and wear 205/70-15`s.
