69DartMatt
Hey guys! Does anyone know the reason this notch is in the trunk floor at the spare tire hold down bracket/gas tank strap mount? The bracket and drop for gas tank straps is notched/shortened to create the hole.
I thought it might have been a design flaw from AMD, but then research showed that it is same as factory.
My body guy filled it with seam sealer. I thought he burned a hole in the floor welding it in so I dug the sealer out to investigate. Is it supposed to be just filled up with seam sealer?
Just wondering because its only on 1 side.
