Anybody running 10s with a small block and factory iron heads
Mopar Racers Forum
  1. ValiantRacing
    ValiantRacing Well-Known Member
    447
    342
    Jun 12, 2009
    El Dorado Ca.
    Local Time:
    8:29 AM
    The ports are not real big, i run a 4.56 gear, this car is not driven on the street, but the engine was in a street car for years, i just put a smaller cam in, and when i done with engine its going in a 73 Duster street car. I have a 340 i going to build.
    • Thanks! Thanks! x 1
    • Demonracer
      Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
      4,959
      2952
      Jan 31, 2010
      Cleveland, Texas
      Local Time:
      10:29 AM
      If you are going for Stock Eliminator, the E,F,G & H classes are a tough playground. There are a lot of SBM running in Division 4 in those classes & most of them can run 1.00 or better under the index without trying.
    • B3422w5
      B3422w5 Well-Known Member
      1,584
      1640
      Feb 9, 2017
      Portage michigan
      Local Time:
      11:29 AM
      doesn't much matter. Its a bracket race at the end of the day.
      Not many( if any) events where a stock or superstocker even if nowhere close to that far under the index cant compete.
    • 70aarcuda
      70aarcuda Master Hoader of SBM FABO Gold Member
      16,310
      4964
      Jan 16, 2005
      las vegas
      Local Time:
      8:29 AM
      Not always a bracket race....friend of mine in his F/SA 340 Barracuda 68 FB has two heads up races in the 1st Divisional Race in Vegas......1st one to the finish line wins
      • Like Like x 1
      • Agree Agree x 1
      • 318willrun
        318willrun Utube channel 318willrun
        16,987
        19043
        Sep 13, 2013
        I'm here
        Local Time:
        10:29 AM
        Yep, in a stocker meet it's like bracket racing unless they are in the same class, then it's heads up.
        • Like Like x 1
        • ValiantRacing
          447
          342
          Jun 12, 2009
          El Dorado Ca.
          Local Time:
          8:29 AM
          I am going to build an engine one of these days for stock, i have a Barracuda i run in stock now, my daughter will run that, i will drive the Duster, my plan is to be in D-SA
          • Like Like x 1
          • B3422w5
            1,584
            1640
            Feb 9, 2017
            Portage michigan
            Local Time:
            11:29 AM
            right. Winning class is the only time it matters. And sometimes you might not even have another car in your class.
            But its 95% bracket racing. That is where the primary focus of the vast majority of guys is.
          • BVoelzke
            BVoelzke Well-Known Member
            361
            374
            Aug 23, 2009
            North Jersey
            Local Time:
            11:29 AM
            Thats cool Valiant ! , some of the D/SA Dusters are flying right now.. theres a local pretty successful stock racer that runs a big block D-E/SA Camaro he tells me the Mopars give him fits as his big block can't run with them ... good to hear!
          • GTX JOHN
            GTX JOHN Well-Known Member
            200
            110
            Dec 12, 2009
            Local Time:
            10:29 AM
            68 Valiant 360 w/ 308 Heads with exhausts ported D like W 2
            3500 Convertor/904 275 low 391 gears 3300 runs 10.80 thru
            mufflers @ 119 in LVMS track @ 3500 FT on Station
            Perf. RPM / 950HP. Street Driver
            It was Hot rod cover car. 408 going in soon with Indy heads.
            360 will be for sale
            Also two 71 Stock 340 Demons that run deep in 10s legal Stock
            Blue one ran 10.60/121.7 @ 3500 ft last week at LVMS
            at Division Race with new engine with break in Oil
            X iron heads/10 to 1 Comp
            Goggle: John Irving Drag Racer
            • Like Like x 3
            • BVoelzke
              361
              374
              Aug 23, 2009
              North Jersey
              Local Time:
              11:29 AM
              That's Cool John , all of your cars here impressive!!!
            • GTX JOHN
              200
              110
              Dec 12, 2009
              Local Time:
              10:29 AM
              Thanks!
              The stocker 340 are the toughest with stock heads intake carb compressoin
              and cam lift. The trick to all these is top rate machine work and LOTS of
              time and patience!
            • QuickDart360
              QuickDart360 Well-Known Member
              1,327
              524
              Apr 5, 2014
              San Antonio
              Local Time:
              10:29 AM
              Did the X heads get any port work? Sounds impressive for stock X'ers!!:thumbsup:
            • GTX JOHN
              200
              110
              Dec 12, 2009
              Local Time:
              10:29 AM
              No sir = We have been to the tear down barn a dozen times
              Heads are carefully CC in the runners intake/exhaust as well
              as valve removed and visually inspected by tech men who are
              usually engine builders and or machinists or Both!
              We do flow/inspect many heads to find the best ones. You would
              be surprised how much these old casting vary from one to another.
              We have 100 plus sets of heads on the shelf.
              • Like Like x 2
              • QuickDart360
                1,327
                524
                Apr 5, 2014
                San Antonio
                Local Time:
                10:29 AM
                Reason I ask is because I have e set of X heads on my 360 in a dart sport and it runs terrific!! But but these at a swap meet many moons ago and being young and on a tight budget just did a valve job and new guides and ran them!
              • rumblefish360
                rumblefish360 So close, yet so far away FABO Gold Member
                40,723
                12259
                Jun 21, 2005
                New York, on a Island
                Local Time:
                11:29 AM
                @GTX JOHN
                I’ve heard the head flow can carry a lot.
                What kind of spread do you see?
              • GTX JOHN
                200
                110
                Dec 12, 2009
                Local Time:
                10:29 AM
                I have seen 30 CFM variance between ones I have
                tested. That does not include some castings that came
                from the factory so darn bad that I rejected them upon visual
                inspection. I have seen exhaust port 1/3 closed from core shift.
                They used the castings over often 10 times back then before discrding
                Look at the # after the 894 IE: - 1 to 9. Every time they used the
                casting they raised the # on diget. Generally the core shift is seldom
                anything but detrimental. The lower the number of times the casting
                was used the better the port configuration!
                • Like Like x 1
                • rumblefish360
                  40,723
                  12259
                  Jun 21, 2005
                  Local Time:
                  11:29 AM
                  Thanks, I’ll keep that in mind, for sure!
                • pittsburghracer
                  pittsburghracer Well-Known Member
                  5,057
                  9197
                  Apr 20, 2016
                  Freeport, PA.
                  Local Time:
                  11:29 AM
                  I flowed a set of stocker heads for a buddy many year ago and it was probably for simplicity reasons one of the most impressive heads I’ve ever had on my bench. It was a free-be job and one that didn’t really interest me because it’s a game I’ve never played or will. I still wish I would have kept a copy of the flow numbers because it got to its max number quickly and never dropped off and went the other way. I know why and how, “valve job angles” and I know it cost 100’s of thousands of dollars to figure it out years ago but these guys that build stocker engines nailed it. Probably 50, or 52, or 55 degree seat angles but when my buddy asked if I could do a valve job for him I laughed and said all I could do is screw those heads up with my simple tools. I told him if he wanted a fast reply ask the shop he bought them from what valve angles they used. Lol . So for the heck of it he did and the guy almost chocked laughing. I’ll just say those heads didn’t hit 250 cfm.
                • furrystump
                  furrystump Well-Known Member
                  1,288
                  831
                  Nov 13, 2004
                  Local Time:
                  4:29 PM
                  So, I have to assume the “somewhat bad heads” would be perfectly fine in a ported condition. The real bad core shift no, but there is some very usable heads on that shelf!
                • GTX JOHN
                  200
                  110
                  Dec 12, 2009
                  Local Time:
                  10:29 AM
                  The ones on my shelf are all pretty decent. The ones that sere real bad we just
                  did not buy unless we got them on an engine. We used to go to Pomona Swap Meet
                  every month for 20 years. You are right if Ported they would be fine BUT with that
                  much core shift I would be a bit nervous about the thickness of the port walls. I guess
                  just do the crummy ports first and if they go thru just toss them out if you have the time. I run stock heads so I am not knowledgeable about porting. The man who said
                  you would never see 250 CFM is ABSOLUTELY right = Stock Xs do NOT flow that on
                  the optimistic flow bench in the country!!
                • Dartswinger70
                  Dartswinger70 Well-Known Member
                  1,986
                  894
                  Sep 20, 2005
                  Southeastern Pa.
                  Local Time:
                  11:29 AM
                  I would think a small block A body could run 10s with stock cast 340-360 ported heads and some "juice"
                • rumblefish360
                  40,723
                  12259
                  Jun 21, 2005
                  Local Time:
                  11:29 AM
                  HP to Weight.... can you make them meet?
                • Dartswinger70
                  1,986
                  894
                  Sep 20, 2005
                  Southeastern Pa.
                  Local Time:
                  11:29 AM
                  Well the A body already has good power to weight in terms of the 340 cars. I mean lighten it up,and go right?
                  • Like Like x 1
                  • rumblefish360
                    40,723
                    12259
                    Jun 21, 2005
                    Local Time:
                    11:29 AM
                    That’s the way I’ll be working the problem!
                    LMAO!
                  • 70aarcuda
                    16,310
                    4964
                    Jan 16, 2005
                    las vegas
                    Local Time:
                    8:29 AM
                    Good luck this weekend
                    Hope you and your son go many rounds in both stock and super stock
                    This will be the first time in 10 yrs I won't be passing out the time slips
                    Don't think Anita will be either
                    Tony
