Are these actually A body seats?
Dusted73
Vermont
When I picked up my 73 duster these buckets were tossed in it, this was originally a bench car, are these even mopar seats if so are they A body seats?
sure look like A-body tracks - can you cut off a couple of hog rings and actually show us what the hinge area on each side looks like? The contour of the seat foam looks a lot like 1970 seats with the center insert running all the way to the skirt in front. What does the seat back look like?
I believe these are later (75/6) A body seats. I had some like this in a 75 valiant brougham. They could also have been from an F body, possibly.
Got a better pic of the hinge cover? Look like 73-up A, 73-74 E body. Tracks look like 73-up A body.
I'm pretty sure I've seen that pattern in a 75/76 Dart sport, but if they are velour, and I believe they are, they are Valiant Brougham/Dart SE.
Those could also be had in 4 door cars. Do they tilt forward? The ones in 4 doors didn't but should be able to be modified to do so.
That's exactly what I did to put buckets in my Duster. 4 door car and had some latches cut that matched the factory latch closely enough.
Sticks in my head that having a map pocket on the back of the seat is a indicator that the seat came out of a 4 door Brougham. I know mine has a map pocket.
They do tilt forward debating keeping them or dropping in seats from a sebring with integral seatbelts.
