ARP main stud interface with oil pump
Discussion in 'Small Block Mopar Engine' started by V8-valiant, Aug 11, 2018.
  1. V8-valiant
    V8-valiant Well-Known Member
    595
    66
    Apr 15, 2007
    GRANDVIEW WA
    Local Time:
    5:53 AM
    Hey guys I’m working on getting my engine together and today have noticed that the arp main stud is in the way of the oil pump? What have others done to correct this? Pull the stud and throw a bolt in? Trim the stud and hope it’s enough for the oil pump to fully seat and seal? Worried about a leak or lack of pressure if the stud is just long enough to not allow the pump to fully seat.
  2. Cal Tonsley
    Cal Tonsley Active Member
    41
    53
    Mar 11, 2017
    Australia
    Local Time:
    10:23 PM
    Used a bolt on mine and still had to narrow the head and grind oil pump to get clearance
  3. grimreaper
    grimreaper Cross Member
    3,674
    461
    Jul 8, 2005
    Gillette, WY
    View My Photos
    Local Time:
    4:53 AM
    Here's how it's gone for me several times. I call ARP and tell them of the stud clearance issue. They tell me that they have not had previous reports of a fit problem. After some pesistance I suggest that they check for a bulletin regarding the issue. They put me on hold. Then they tell me it has not been a problem for others but that they do have a special bolt that they can send me. In a few days a "special" bolt arrives and I check fit to se if the head is low enough. Usually after some minor clean up of the oil pump housing the new bolt provides a couple of thousandths of clearance. If not, I take the bolt to my belt sander to buff a few thousandths and get a fit. I hate putting in a bolt after spending money on a stud kit but on the rear cap I find no perfect solution. Seems like ARP would properly address the issue but we are only Mopar folks after all.....
    • Agree Agree x 2
    • Like Like x 1
    • 1Fast340
      1Fast340 Well-Known Member
      1,156
      353
      Dec 30, 2011
      Sweden
      Local Time:
      12:53 PM
      That never happend to me before!Havent we all said that at some point in time....
      Most either cut down the stud and get a shorter nut to make it work or run a bolt instead,yep its stupid.
      Bolt on parts tend to be cut to fit,gap to spec and paint to match.
      • Like Like x 1
      • TrailBeast
        TrailBeast Slightly Twisted Member
        19,076
        5329
        Mar 11, 2011
        Arizona
        View My Photos
        Local Time:
        4:53 AM
        If I had a dollar for every time I have seen that I would have, well, 5-6 dollars.:D
        Some have cut the stud down, and some used a bolt there because of that.
      • yellow rose
        yellow rose Doctor of Thinkology.
        15,415
        12016
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        3:53 AM
        Shorten the stud and mill down the main cap. Been doing it for years. Had to do it my last build. Will have to do it to the next one
        • Like Like x 2
        • V8-valiant
          595
          66
          Apr 15, 2007
          GRANDVIEW WA
          Local Time:
          5:53 AM
          Thank you guys for the suggestions. I will call ARP on Monday and see where I get with them. Just seems silly for it to not work? Is there a difference on the pump body between hi volume and a standard pump?
        • grimreaper
          3,674
          461
          Jul 8, 2005
          Gillette, WY
          View My Photos
          Local Time:
          4:53 AM
          No difference on the main cap side.
        • 70aarcuda
          70aarcuda Master Hoader of SBM FABO Gold Member
          13,959
          2036
          Jan 16, 2005
          las vegas
          View My Photos
          Local Time:
          3:53 AM
          Used a stock bolt under the oil pump
          • Like Like x 1
          • Max1196
            Max1196 Well-Known Member
            563
            295
            May 12, 2016
            Swift Current SK
            Local Time:
            5:53 AM
            Going to be agreeing with Yellow Rose here, Work with what's provided. ARP aint gona help. Trim it, check, measure, it'll fit eventually! 100_1021.JPG
            • Agree Agree x 1
            • KnuckleDuster
              KnuckleDuster Well-Known Member
              1,636
              630
              Nov 9, 2005
              Texas
              Local Time:
              6:53 AM
              ARP still playing dumb on this?
              I like their products, but customer service is pathetic.
              They know, they just don't care.
              Went through this with them in 2005, and had to PAY for a bolt.
              Seen it countless times since then.
              • Agree Agree x 1
              • Teedog
                Teedog Active Member
                27
                3
                Jan 7, 2014
                Mt Gambier SA
                Local Time:
                10:23 PM
                Do 'Milodon' do a Mains Stud Kit also? Never tried one because everyone just goes straight to ARP..... but I wonder if their kit has the same issue?
                In this case I guess....modification of the ARP Stud is what I would be trying.
              • famous bob
                famous bob mopar misfit
                11,036
                2676
                Aug 14, 2011
                okla
                Local Time:
                5:53 AM
                Such is the life of a hotrodder: cut the dam stud and nut down !
              • raymond
                raymond Well-Known Member
                147
                4
                Aug 27, 2004
                Australia
                Local Time:
                11:53 AM
                While you engine is at the machinist, get them to spotface your rear cap down to clear the nut and washer. Then cut the stud to suit, why put a bolt in that position after buying a stud set ?
                • Like Like x 1
                • moper
                  moper FABO Gold Member FABO Gold Member
                  15,374
                  1478
                  Dec 27, 2004
                  eastern CT
                  Local Time:
                  11:53 AM
                  yeah - tech line 101: "really? We've never heard of that...".
                  For 20 years now I've just cut the stud down, use the 12 point nut, and you may need to grind the chamfer off the end of the nut. Some I've had to, some I haven't. I also always run an oil pump gasket - I know some here don't and that will effect what you have to do too.
                • mbaird
                  mbaird mbaird FABO Gold Member
                  3,948
                  1189
                  Dec 10, 2005
                  boise, Id
                  Local Time:
                  4:53 AM
                  I just went through this.
                  Called ARP....they had never heard of such a thing.... sent me correct bolt...lol
                  • Like Like x 2
                  • 1Fast340
                    1,156
                    353
                    Dec 30, 2011
                    Sweden
                    Local Time:
                    12:53 PM
                    I would guess that ARP when they first made that kit measured everything up and forgot all about the oilpump even existing. Skip forward to the first complaints and someone probably thought it was an anomaly of some kind creating the problem and at that point the whole "we never heard that before" stuck in the vocabulary and if someone mentioned it to engineering,engineering probably said we measured this in the past and its correct and even if it isnt we cant shorten that stud since that would make the threadengagement to short to be optimum and we dont want that to happen.
                    • Agree Agree x 3
                    • nm9stheham
                      nm9stheham Well-Known Member
                      9,750
                      2167
                      Dec 20, 2013
                      Waynesboro, VA
                      Local Time:
                      6:53 AM
                      Don't cut the nut down, or the thread stress will go up on both nut and stud. No need to do that.
                    • moper
                      15,374
                      1478
                      Dec 27, 2004
                      eastern CT
                      Local Time:
                      11:53 AM
                      That stud and nut combo is so over-the-top to hold that position the loss of .030 or non-threaded taper doesn't change anything or diminish crap. Some guys just use the factory bolt. That bothers me because my blocks get align honed with the stud in place.
                      • Agree Agree x 1
                      • flyfish
                        flyfish C8H18+N2O = :-D
                        1,680
                        172
                        Apr 16, 2007
                        Indy
                        View My Photos
                        Local Time:
                        6:53 AM
                        I have cut the stud in the past and did some grinding on the pump for clearance. The motor I just built I used a single ARP bolt for that one, studs on the rest (along with some clearancing on the pump). Either way will work.
                        • Agree Agree x 1
                        • Sterling
                          Sterling Well-Known Member
                          100
                          30
                          Sep 29, 2007
                          Pottstown,Pa.
                          Local Time:
                          6:53 AM
                          I usually mill some off the old pump and mill the cap down for clearance
                          • Agree Agree x 1
                          • Bighead440
                            Bighead440 Well-Known Member
                            144
                            91
                            Jun 18, 2017
                            Milledgeville, Georgia
                            Local Time:
                            6:53 AM
                            NEVER cut the nut. Use the 12pt nut and cut the STUD until it's just proud past the nut. Then relieve the pump casting for clearance. Easy-peazy, been doing that for 20+ years.
                          • 72Dart6pack
                            72Dart6pack Harder Better Faster Stronger.
                            2,703
                            1735
                            Feb 1, 2016
                            Roseville Michigan
                            Local Time:
                            6:53 AM
                            Really? 21 posts to figure out the post above me is correct. Yikes!
                            • Thanks! Thanks! x 1
