Axle U Bolt Torque Specs?
2fine69s
69 340-6pak Rag Top
Elm City, N.C.
Hey guys,
Just put the 8.75 back in my 69 Dart. Does anyone know the torque specs for the axle U-bolts?
Thanks,
Martin
I'm almost where you are, and I've been instructed that 45lbs is where you want to be for the u-bolts.
The leaf-spring needs to effectively "suspend", and cranking down too much prevents this, keeping the spring from working as designed (correct pinion-angle is very important to this function as well).
Tightening down too much will affect both traction and ride.
You're welcome Homie. You probably already got this part, but I wanted to also mention that after installation, drive the car briskly for a week (or 100 miles or whatever) and re-torque those u-bolts.
