matty wardle
mopar dedicated
hi guys,
i know its an ebody but most of the knowledge is on this site so here goes,i,m trying to bleed the brakes on my 73 cuda,all stock brake system with front discs,in my original service manual it says that the proportioning valve in e bodies is mounted vertically,not horizontally,so in order to bleed the back brakes you have to crack a front bleed nipple so the system thiks the front has had a brake failure,so the proportioning valve will send all the pressure to the back,the master is rebuilt,i,ve cracked a front nipple and tried and tried to bleed up the back i just cant get any fluid thruogh to the back,the peddle is going to the floor but not one bit of fluid is leaving the master cylinder pot for the backs,the front will bleed up beautifull,i,m thinking my prop valve is not working properly its been on since 73,i,ve taken it off and i think i will put a new one on,anyone had this problem with getting the backs to bleed,maybe its just an ebody thing-----any suggestions answers:banghead:
