Baffle for factory oil pan.
Bad Sport
HALF A BUBBLE OFF
Staff member
Legendary Member
The Wolverine State
Just thought I would toss this out there if anyone needs it. I am using a 392 pan, with the factory pickup.
You can open the .pdf and print it, or you can save it to a folder.
It prints on 8 1/2 x 11 paper.
Cool! Have you thought about a small notch in the rear corners? I'm just thinking about the returns from the heads in the back....not that there should be a lot back there with a stock rocker oiling system.
There is a slight gap all the way around the plate, I also plan to coat the inside with Glyptal paint to 'slicken' it up, lol. As well as the valley up top.
I made one for a stock pan and had a Milodon windage tray. The baffle bent the ear of the tray in just enough when I installed it that a rod bolt was nicking the tray. I found out when I got the motor in and cranked it. I didn't know where the racket was coming from. I first thought it was a convertor bolt. I pulled the engine back out...
I was PISSED! So much that I bought a Kevko pan and ditched the tray.
So check your clearance and turn the motor over if it's out of the car.
Why didn't I see this yesterday? I just built one for same pan yours looks better. but I figure no one else will see mine so I'm good with it. almost exact same design as yours.
Cool stuff...very similar to what I crafted and that was based on a mag article...not sure which Mopar mag though.
Here is what mine turned out like:
i used epoxy to affix the first baffle I made when lowering the stock pan a couple of inches. The first time I took the pan off afterward, found out the baffle had fallen off. Oh well.
Ya, I'm sure the oil would eat away at that epoxy
Vibration is killer also. I would lean toward a plug weld with a flange
