Is it OK to take power off the terminal on the ballast resister to fun an electric fuel pump? I tried reading up on what the resister is for, and it sounds like the voltage changes? To me I think it is not a good idea. 65 slant 225 valiant
Thanks, the pump is on the top of the shock mount, front passenger side, done by previous owner. No issues starting up, but pump stops pumping after 10_15 min. Just starting to trouble shoot it . I don't see a relay just the 2 wires out of the pump, 1 to ballast,neg to battery. Unless relay is built in pump.
Electric pumps should be AS CLOSE TO THE TANK as possible. "That is all."
Thanks for the helpful info , it is hard to trouble shoot what previos owners have done , without sites like this one could waste a lot of time and money. So last night a put a bag of ice on the pump to see if it would still run dry , it ran about an hour , the level of fuel in the filter slowly got lower. I could see small spurts of fuel ever few seconds coming threw. I shut it off. turn the key on and the pump did not pump. waited 15 min. turn the key on pump filed the filter. started it back up put ice on the filter , let it run , it did the same thing. Any ideas before I buy the relay , and a new pump ?This is oft-stated, even by Holley and other EFI vendors, but doesn't make it true. I mounted an EFI pump in the lower engine bay in my 3 Mopars. My 65 Newport has run that way since ~1998. Prior to that, I tried the "mount near tank", with much fussing and it is hardly accessible for roadside repairs. If you test it, fuel just pours out of the 5/16" factory supply tube (or should), so I can't imagine it restricting the pump inlet. Re "priming", someone here asked Walbro and they said their EFI pumps can suck fuel up to 5 ft high, so no concerns there (unless climbing a 20 deg grade).
You could power the EFI pump directly off the key switch (IGN circuit), but the current draw and inductive kick-back could burn up your switch, and the extra draw could draw down your ignition voltage, as others mentioned, making for a weak spark. Always smart to power via a relay (and fuse) from BATT+. You can tap BATT+ at the big stud on your starter relay (firewall).
Re your ballast question, it is to reduce the voltage to the coil when the engine is running. That wasn't just a Mopar thing. Many here changed to a newer HEI ignition system that gives a stronger spark and runs directly off battery power, hence no more ballast.
Just as a side note....the ballast resistor' purpose is to perform a crude current regulation through the coil that keeps coil heating under control over a wide range of RPM's. The electrical term 'ballast' means just that: a resistive element that varies it's resistance based on the current flowing through them. There were ballast tubes in the old vacuum tube days that did the same kind of thing: current regulation.
The voltage drop from the ballast is just a byproduct of their current regulation. It is not precise current regulation by any means like a solid state regulator, but it does keep the current flow and heating of the coil within a rough range despite wide variations in RPM.
The condenser is what you may be thinking of that helps keep the points from burning up. Often when a condenser opens up, you get rapid metal transfer from one side of the point to the other and the points get all messed up.In all due respect I think you are wrong about "what the ballast resistor is for" I always thought it was to keep the points from burning out. And I still think that. But now that I give it a little more thought, they did still use them for electronic ignition. So maybe im incorrect? MT
There ya go.... good explanation with the dwell change. It was hi-tech for the day!The ballast resistor is used to limit idle/low speed current to the coil because
actual dwell time is high at those speeds,the resistance actually goes up as
the resistor heats up during high current demands, then back down as you rev.
unfortunately it is slow to respond to quick changes........
