Corrupt_Reverend
Okay, I've got the 904 completely torn down and getting ready to rebuild, and do the transgo tf3 MVB conversion.
In preparation, I'm reading through the MVB instructions and came across a note on "the best method for band adjustment".
I've read of this before but only once and thought it might not be a good way to go about things.
It's the whole deal where you lock up both bands, then loosen one until you can just start to turn the driveshaft, then back off half a turn. Change directions and do the same for the other.
The other method that I thought was the go-to way was tightening to 72 in/lbs then backing off two turns (or whatever it was).
I figure transgo knows a thing or two about this stuff so I'm not really sure which way is better.
How do you guys do it? Play it by feel, or use a torque wrench?
