BB K member rookie
Mojack
Bristol, Tn.
From what I read here at FABO it looks to be a 68-69 correct? ...and it takes a special block with extra threaded bosses on the driver side front?
I know pretty much of nothing when it comes to factory BB A bodies. I got a K member in a package deal with some other stuff. Its been chopped for an oil pan and poorly repaired. It came from a drag car, but I don't think it was an original BB car. Does this thing look like a real factory K?
Yes it is, but it also looks like it had some modification on the drivers side front of the motor mount, probably had a bigger oil pump with an AN fitting on it, seen that happen before. Will it be for sale?
Best way to tell, if it is a true BB K-member, is to look at the steering box mount.
First pic. See the mount kind of sits in line with the K-member. BB and quite sure also the ´68 SS A-Body, had this steering box mount placement.
Second pic. Small block K-member.
Two different PN.
Not talking about what DC later offered.
Well It does have a raised steering mount, does that disqualify it as a real BB K member? It really doesn't look like it been cobbled from a small block K.
HemiSSDart you have a good eye . The driver mount has been clearanced. BTW your in box is full.
It’s a big block A-body k-frame. You can tell because the nose of the steering box points straight at the left motor mount.
