[SOLD] BBP 8 1/4 set up for sale
Sedanman
67-9 Valiant specialist
chicago Il
I'm selling my 276 geared BBP 8 1/4 set up with shock plates,u bolts,backing plates & drive shaft for 108 wb cars. It has 2 new outter axel tube seals,new brake lines,rubber hose & new u joints in d shaft & was blasted & primed. The gears & insides were in great shape when I took the axels out to put new seals in. This set up is for a 904 or 4spd trans with 8 1/4 in a 108" wb abody. I'm putting an 8 3/4 in my 67 Valiant as soon as my axels arrive & won't need the current rear,you will need drums,brakes & hardware,the backing plates will be bare. This is a direct bolt in for 67-73 valiant sedan,67-9 cuda,70-6 duster,73-6 dart sport with a 904 trans. The rear & shock plates are all that can be used on darts since they are 111" wb & the d shaft will be too short. $400 obo & pick up only. I will not split up. 60108 zip
If I had the cash I would be at your house right now picking it up. Good luck with the sale Chuck. If you need a hand with anything just give me a call.
Bump
I have most everything here now to put my 8 3/4 together & will be swapping this out soon. Offers?
Good looking stuff for a good price .... just not for me. Thanks
This is a complete bolt in unit,just put it under the car,hook up the brake lines,d shaft & add brake hardware & drums and go. This was out of my daily driver that is under construction that is getting an 8 3/4.
keep that together..thats a good deal for someone looking to upgrade..c/ilst ought have someone looking..j
Gonna give it 1 more shot here before I part it all out. If I part it : $100 for the Drive shaft with new joints,$75 for the blasted & primed shock plates,$60 for the blasted & primed 10x2.5 backing plates,$40 for both new steel lines & new rubber line,$10 for the snubber,$75 for the axels,$100 for the housing with gears. Shipping not included & pick up only on the housing or $350 for all of it
